Hello,
I would like to separate a polygon that represents a road network into several polygons or polylines. I do not know what functions to use to display vertices and nodes.
Thank you in advance for answers that guide me.
Yvan
Hello,
Yvan
Yvan,
could you please state your intention ? and clarify how your network is
represented : are roads delimited by polygon boundaries and crossroads
by nodes ? or was the network digitized as a polygon (I mean giving
roads thickness) ?
First, about data type conversion, you can have a look at v.type.
Yours,
Vincent.
Le mardi 09 février 2010 à 15:14 +0100, Yvan Paillé a écrit :
Hello,
Thank you in advance for answers that guide me.Yvan
grass-user mailing list
grass-user@lists.osgeo.org
AFAIU :
* your network was digitized as a single polygon, contouring
streets/roads and crossroads in one go ;
* you would like to turn it into a linear reference network.
Am I right ?
If no special splitting was initially performed on boundaries to
distinguish between connected street sections I fear you'll have to do
things manually...
Vincent
Le mardi 09 février 2010 à 16:03 +0100, Yvan Paillé a écrit :
My road network was digitized into a polygon. Initially, I need to
separate into two distinct parts by half. In a second time, I need to
cut each polygon based on the streets and of belonging to adjacent
parcels. As if I would define a sidewalk.Only the first step is already causing me problems.
Thank you
Yvan
Vincent Bain a écrit :
> Yvan,
> roads thickness) ?
> Yours,
> Vincent.
>> Hello,
>> Yvan
>> _______________________________________________
well,
depends on what accuracy you require, but an automated method could
however fit your needs :
v.to.rast -> r.thin -> r.to.vect -> v.clean
i.e :
turn your polygon into a raster map,
perform a thinning on the resulting map,
turn back this rasterized/thinned network into a vector map,
optionnally clean extra nodes with v.clean.
Hope this helps,
Good luck,
Vincent
Le mardi 09 février 2010 à 16:41 +0100, Yvan Paillé a écrit :
Yes, that's it!
Good well, I'll take my pain with patience and digitize point by point.Thank you
yvan
> AFAIU :
> Am I right ?
> things manually...
> Vincent
>> Thank you
>> Yvan
>>> Yvan,
>>> roads thickness) ?
>>> Yours,
>>> Vincent.
>>>> Hello,
>>>> Yvan
