Many thanks Markus...
I did this way (for a line only, which has category=163 ... now I will
create a cycle for each line of the map):
with this I obtain the length of the line subtracted of 20 meters:
echo "`v.report map=Reticol layer=1 option=area units=meters | grep 163
| cut -f3 -d'|'`-20" | bc -l
with this I create a segment which is 40 meters shorter than the
previous one (20 meters from each node):
echo "L 1 163 20 3434.21" | v.segment input=Reticolo_050407_LAST
output=prova
but no way to do v.overlay with two lines, so I create a buffer of 1
centimeter around the line:
v.buffer input=prova output=prova_buf type=line layer=1 buffer=0.01
scale=1.0 tolerance=0.01
then I will put all the buffers into a single map (v.patch)
and at the end:
v.overlay to obtain the lines network cutted of 20 meters at each
node...
Grazie...
Ivan
Il giorno dom, 08/07/2007 alle 12.27 -0700, Markus Neteler ha scritto:
ivan marchesini wrote:
> Dear Users...
> I have a vector lines map...
> I would like to shorten each line of the map.... the amount of the
> shortening could be fixed (10 meters.. may be)
> I would like to do this in each part of the line... i.e.:
> old lines:
> ____________
> new lines:
> __________
> any idea about a quick way to solve this problem...???
> thanks...
> Ivan
Hi Ivan,
pseudo-code (for a script or so):
- fetch all vector lengths with v.report
- calculate length - desired shortening (nice SQL excercise)
- use v.segment with
L <segment id> <line cat> <start offset> <end offset>
to create the segments at then end to be removed
- use v.overlay with NOT
cheers
Ti prego di cercare di non inviarmi files .doc, .xls, .ppt, .dwg.
Preferisco formati liberi.
Please try to avoid to send me .doc, .xls, .ppt, .dwg files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini@unipg.it
ivan.marchesini@gmail.com
tel: +39(0)755853760
fax (university): +39(0)755853756
fax (home): +39(0)5782830887
jabber: geoivan73@jabber.org
