Hello Glynn.
It's 6 * exp {-3.5*abs(Slope+0.05)}
So I guess it goes newmap="(6 * exp(-3.5*(abs(slopemap)+0.05)))/0.025"
0.025 it's for Distance (cell resolution). The Hiking Function estimates
distance in Km and my DEM it's 25x25m.
Do you think this syntax is correct, now?
Thank you.
Miguel Lage.
----- Original Message -----
To: <mlage@usal.es>
Cc: <grassuser@grass.itc.it>
Sent: Friday, January 26, 2007 5:16 AM
Subject: Re: [GRASS-user] Tobler's hiking function
mlage@usal.es wrote:
Thank you very much, Glynn.
The original Hiking Function is:
W= 6 exp {-3.5*abs(Slope + 0.05)}
Through this I want to estimate anisotropic cost movements in friction
surfaces.
Maybe the problem is that I haven't understood the r.mapcalc syntax...
My problem is that I don't understand your syntax; what does "X exp Y"
mean?
>> surfaces.
> mean?
It looks okay.
Although, for future reference, you should normally quote the entire
expression using single quotes, e.g.:
Using single quotes ensures that nothing is changed by the shell. Use
double quotes if the expression contains shell variables or command
substitutions which need to be expanded before being passed to
r.mapcalc.
Also, you can use the ewres() and/or nsres() functions rather than
hard-coding the resolution, e.g.:
