[GRASS-user] topo map to dem
I apologize if this question has been posted before, but I couldn't find something searching through the mailing list.
Is it posible to perform the task of extracting a DEM from a scanned topographic map in GRASS? I mean like Autodem or R2V programs.
TIA
Antonio
it helps if you know the secret words, try searching for "r.thin".
using r.resample or r.mapcalc, or maybe with "select by color" in a
graphics program, select only the lines you are interested in, make
every thing else white/NULL. You might have to use v.mkgrid + v.buffer
to get rid of any lat/lon grid lines the same color as isolines.
Once you only have raster versions of the isolines, run r.thin to get
rid of noise, then run "r.to.vect feature=line".
then add an elevation column to the vector map (v.db.addcol), v.digit or
QGIS to clean out junk, and "d.what.vect -e" to label lines with
elevation values.
Finally use v.surf.* or r.surf.contour to convert into a DEM.
I've done this with bathymetry charts and it takes some manual labor but
works pretty well.
Hamish
elevation values.
works pretty well.
Hamish
Thanks for the advice! I will try to do it this way
Antonio
