[GRASS-user] topological errors in v.extract results
Dear all,
At the moment I am struggling quite a bit with GRASS topology errors for two of my maps which result from v.dissolve.
Input maps are imported with v.in.ogr without topological errors. However, the output maps from v.dissolve result into
406458 areas, but only
182176 centroids
in map A and
1058018 areas, but only
995283 centroids
in map B
After patching and cleaning both layers v.to.db gives no correct result for sides. Often areas have –sides like this:
cat>left>right
1||-1|
Then I ran v.build -e on both in order to investigate.
For both, the number of errors reported by v.build is exactly the difference between the number of areas and the number of centroids in each map.
Any hints or suggestions for alternative approaches to dissolving areas with common attributes?
I am interested in the individual areas (= one category and one entry in the attribute table per area) anyway and will try v.extract directly, if that sounds reasonable?
Stefan
Short update: I see that the difference between number of areas and number of centroids is already present after v.in.ogr…
Is that correct?
Is not an area defined as a closed boundary with a centroid inside? Should not then the number of centroids be equal to the number of areas?
I am using GRASS GIS 7.0.4 on Ubunut 14.04 LTS BTW.
I try to compare with GRASS GIS 7.1 but import there is painfully slow.
So I had at: https://trac.osgeo.org/grass/ticket/2185
However, I use exactly the same data, from the same database, on the same (local) harddrive in 7.1 and it is just !much! slower than 7.0.4 on import… Snapping vertices Step 1 takes significantly longer than with 7.0.4
Cleaning topology in 7.1 from a GRASS vector map earlier imported with 7.0.4svn is BTW not noticeably slower in 7.1 compared to 7.0.4…
I am glad for any hints,
Stefan
On Wed, Aug 17, 2016 at 11:54 AM, Blumentrath, Stefan
Is that correct?
Areas without centroid are generally ok, they are holes inside other
areas, equivalent to inner rings of shapefile polygons. As long as
there are no warnings in the output of v.in.ogr or v.build, there are
no topological errors.
import... Snapping vertices Step 1 takes significantly longer than with
7.0.4
There is no GRASS 7.1, so I guess you mean 7.2 or trunk. Are you using
the environment variable GRASS_VECTOR_LOWMEM? This variable affects
snapping only in 7.2 and trunk: less memory but longer processing
time.
Markus M
7.0.4svn is BTW not noticeably slower in 7.1 compared to 7.0.4...
Stefan
grass-user mailing list
grass-user@lists.osgeo.org
7.0.4
G72 and trunk use a new search tree for snapping that needs much less
memory. Unfortunately, balancing this search tree did not scale well
with millions of vertices. I improved the balancing method in trunk
r69253 and G72 r69254.
Markus M
Stefan
Thanks Markus!
-----Original Message-----
From: Markus Metz [mailto:markus.metz.giswork@gmail.com]
Sent: 25. august 2016 18:36
To: Blumentrath, Stefan <Stefan.Blumentrath@nina.no>
Cc: grass-user grass-user (grass-user@lists.osgeo.org) <grass-user@lists.osgeo.org>
Subject: Re: [GRASS-user] topological errors in v.extract results
On Wed, Aug 17, 2016 at 11:54 AM, Blumentrath, Stefan <Stefan.Blumentrath@nina.no> wrote:
same
with
7.0.4
G72 and trunk use a new search tree for snapping that needs much less memory. Unfortunately, balancing this search tree did not scale well with millions of vertices. I improved the balancing method in trunk
Markus M
Stefan
