[GRASS-user] TPIE-based algorithms in GRASS ?
As Ms. Helena Mitasova was involved int it, I would like to know if GRASS is making use (or is planning to) of the research work done by the STREAM project [1] such as TPIE?
Their various publications are showing quite an impressive efficiency on using these I/O methods to generate a grid DEM from a huge dataset in comparison with surf.rst. I've not been able to find out an open-source software based on it as it seems most of the (TERRA)STREAM's devs are now behind the proprietary SCALGO software.
Being able to manipulate LIDAR datasets without resorting to tiling and multiple regions would be a great thing ! Martin Isenburg is using a similar approach in his blast2dem tool, the processing/results are great.
MORREALE Jean-Roc
[1] STREAM - http://www.cs.duke.edu/terrain/
