[GRASS-user] Traceback in running my first script
someone know this error that appears in running my first script in windows 7.0 with grass 6.4.4 mysys
‘import site’ failed; use -v for traceback
File “C:\Program Files (x86)\GRASS GIS
6.4.4\etc\gui\scripts[v.WESdaSDFtoGRASS_rev4.py](http://v.WESdaSDFtoGRASS_rev4.py)”, line 87,
in
import sys,os,re,numpy,math,string
6.4.4\Python27\lib\os.py”, line 398, in
import UserDict
6.4.4\Python27\lib\UserDict.py”, line 84, in
_abcoll.MutableMapping.register(IterableUserDict)
6.4.4\Python27\lib\abc.py”, line 109, in register
if issubclass(subclass, cls):
6.4.4\Python27\lib\abc.py”, line 184, in subclasscheck
cls._abc_negative_cache.add(subclass)
6.4.4\Python27\lib_weakrefset.py”, line 84, in add
self.data.add(ref(item, self._remove))
TypeError: cannot create weak reference to ‘classobj’ object
Best regards
Giuliano
On Tue, Oct 21, 2014 at 5:09 PM, Giuliano Urgeghe <giuliano.u@gmail.com> wrote:
'import site' failed; use -v for traceback
You may need to check of the PYTHONHOME variable is set properly.
  File "C:\Program Files (x86)\GRASS GIS
6.4.4\etc\gui\scripts\v.WESdaSDFtoGRASS_rev4.py", line 87,
in <module>
6.4.4\Python27\lib\os.py", line 398, in <module>
    import UserDict
6.4.4\Python27\lib\UserDict.py", line 84, in <module>
6.4.4\Python27\lib\abc.py", line 109, in register
6.4.4\Python27\lib\abc.py", line 184, in __subclasscheck__
6.4.4\Python27\lib\_weakrefset.py", line 84, in add
TypeError: cannot create weak reference to 'classobj' object
Best regards
Giuliano
grass-user mailing list
grass-user@lists.osgeo.org
