[GRASS-user] Tracing dotted lines from raster (and convert to vector)
Dear list,
I am curious to find out if it is possible to successfully convert the
"boundaries" of a raster map (contains some administrative boundaries)
in
a vector map.
The problem with this raster map is that the boundaries
are represented by non-continuous lines (dots).
Here is the link to the bad-looking gif files which contain
administrative boundaries (prefectures in Greece):
http://www.ypes.gr/kapodistrias/greek/kapo/nomoi.htm
Is there a way to get the biggest portion out of it as vector
lines/boundaries and correct manually as less as possible?
Thank you,
Nikos
P.S. My "quick" attempts so far
(a)
I 've tried using r.zc (edge detection) with no satisfactory results.
(b)
1. Save gif from http://www.ypes.gr/kapodistrias/images/i_trik.gif
2. grass -text # and create an xy location
3. r.in.gdal input="/grass_db/kapodistrias/data/i_trik.gif"
output="trikala"
4. d.rast trikala cat=3 # cat=3 is the blue color, that is the
boundaries of interest.
5. r.mapcalc trikala_3="if(trikala == 3, 3, null())"
6. r.thin input="trikala_3" output="trikala_3.thinned" iterations=200
7. r.to.vect input="trikala_3.thinned" output="trikala_3_thinned"
feature="line"
8. v.clean input="trikala_3_thinned" output="trikala_3_thinned_clean"
type="line" tool="snap,rmdangle,rmbridge,rmdupl" thresh=16
Probably only snap help here but anyway I tested several options. snap
threshold above 20 and below 14 gives few/bad lines.
If there is a way to connect the "blue dots" in the raster map then I
suppose it would be more or less easy to grab lines from the raster
map.
On Friday 23 May 2008, Nikos Alexandris wrote:
Dear list,
in
a vector map.
Thank you,
Nikos
(a)
(b)
output="trikala"
feature="line"
map.
I have found that when you are working with discontinuous line segments that
don't have gaps too large -- it is possible to "re-connect" the lines with
the following procedure:
1. extract only the color of interest
2. use r.grow to "fatten" the segments until they touch
3. use r.thin to return the segments to linear feature
4. vectorize with r.to.vect
I have used this approach with area features as well. See this link for some
ideas:
http://casoilresource.lawr.ucdavis.edu/drupal/node/244
Dylan
Dylan Beaudette
Soil Resource Laboratory
University of California at Davis
530.754.7341
On Fri, 2008-05-23 at 17:46 +0200, Nikos Alexandris wrote:
Dear list,
in
a vector map.
Thank you,
Nikos
(a)
(b)
output="trikala"
feature="line"
map.
O.K.,
I feel I am closer to the target.
I used r.grow and then r.thin.
Now it looks much better but I have lots of small-length lines left and
right from the borders.
v.clean tool=rmdangle does halfway the job.
How do I tell GRASS (v.clean?) to remove lines of small lentghs?
2008/5/23 Nikos Alexandris <nikos.alexandris@felis.uni-freiburg.de>:
try v.edit, e.g.
v.edit map tool=delete query=length thresh=-1,0,-50 type=line
which removes from vector map all lines with length shorter than 50 map units
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
ideas:
Dylan
Yep,
it works great. Also here
http://grass.osgeo.org/wiki/Trace_vector_contours_from_a_scanned_map
which might be yours :wink:
Thanks.
It feels good that I also "found" the same way more or less in the end.
I noticed the "trick" of keeping the color of the lines of interest
afterwards.
Martin,
it removes more than what I would like it to remove.
Even with a small thresh like:
v.edit trikala_3_grown_thinned tool=delete query=length thresh=-1,0,-5
type=line
Anyhow,
the v.clean tool=rmdangle works fine with the proper thresh value.
Thank you,
Nikos
type=line
tool=length -> tool=dangle
does the same job as v.clean.
Anyhow,
Martin
