[GRASS-user] Trouble getting started
I am totally new to grass and having trouble.
I installed grass from RPM on my Fedora 30 linux system. First I installed 7.6 from official fedora packages, then I erased that and installed 7.8 from packages on the Fedora "copr" repository. I downloaded the sample North Carolina dataset for version 7 (145M). I untarred that into /home/tom/grassdata and when I browse to that, grass seems to find it and is ready to go. But when I click on "Start Grass Session" I get two empty and useless windows and see the messages:
(wxgui.py:30767): Gtk-CRITICAL **: 20:37:16.297: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkScrollbar
I get the exact same with 7.6 and 7.8.
The useless windows call themselves "layer manager" and "map display".
This seems like a reasonable way to get started. What if anything am I doing wrong, or is this some known bug?
Hi Tom,
Le Thu, 14 Nov 2019 20:40:31 -0700,
Welcome to the community !
GRASS GIS does have a bit of a learning curve, but once you get past
the first barriers you won't be able to live without it anymore ! :wink:
When you say "empty", what does that mean exactly ? Could you provide a
screenshot ?
and see the
GtkScrollbar
GtkScrollbar
These are just annoying messages, but harmless and AFAIK do not
explain your issue.
These two windows should open by default when you launch the GRASS GIS
GUI, but they should contain buttons and menus.
If they do, then the next step for you should be to use the layer
manager window to add a map which should then appear in the map display
window.
Have you had the opportunity to read these to introductions:
https://grass.osgeo.org/grass78/manuals/helptext.html
https://grasswiki.osgeo.org/wiki/Quick_wxGUI_tutorial
Also check here:
https://grass.osgeo.org/documentation/tutorials/
for some more in depth tutorials.
At this stage we need a bit more info to really know.
Moritz
Le Fri, 15 Nov 2019 11:27:54 +0100,
Moritz Lennert <mlennert@club.worldonline.be> a écrit :
Hi Tom,
Another question: when exactly did you install these packages. 7.8.1
just arrived in the repository 3 days ago, IISC, so if you still have
7.8.0 you might want to start by installing the latest version.
Moritz
Hi Moritz,
Thank you for your help and advice. I am running 7.8.1RC1 as it turns out, installed yesterday.
I was overly alarmed by the error messages (they do say "Critical Error" after all) and along with
getting two blank windows, I just assumed that something serious was wrong.
I do think that it would make sense for somebody to fix whatever it is that yields the messages like:
(wxgui.py:419): Gtk-CRITICAL **: 21:21:42.695: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkSpinButton
In fact I note that the window I used to start GRASS is filled with messages of this sort.
Likely that the Gtk libraries have become extra fussy or something, but it would be nice to clean this
up as it will alarm new users (or any sensible user I would think).
My blank windows do have buttons and when I ignore the error messages that continue to spew out, I do get
results! I had expected that I would immediately see some kind of map, not just a blank canvas to start, so on
with the learning curve I go.
 Tom
Hi Tom,
Moritz
Hi Tom,
On Fri, Nov 15, 2019 at 5:05 PM Tom Trebisky <tom@mmto.org> wrote:
Hi Moritz,
Yes, these GTK error messages are annoying a big time!
Seems nobody knows how to get rid of them. See your preferred search
engine that many software packages with terminal support + GUI suffer
from them...
Fully agreed. The thing is that they are rather impossible to debug.
It says line 419 but there is nothing related.
Again, fully agreed.
That's a different topic but also agreed :wink:
I see. Well I have done my share of Gtk programming in C and via Ruby and I remember things of this sort (messages that were difficult or impossible to relate to code), especially when callbacks are registered. I presume (or get the impression) that you are a developer and not just an end user of Grass.
I find myself half tempted to clone the Git repository and try to build Grass from sources, but this is not why I got involved here. And I am sure better minds than mine have already looked at this issue.
I might presume/guess that this has been identified as an upstream issue in the Python/Gtk bindings or perhaps even in Gtk itself -- and there may be better things to work on than chasing this in hopes that the teams upstream will do something about all of this.
My interests (with regard to Grass) are in maps and geology and I will try to stick to that for now.
Thanks for your friendly reception into the Grass community !!!
 Tom
On 11/15/19 3:26 PM, Markus Neteler wrote:
Hi Tom,
Hi Moritz,
from them...
See https://trac.osgeo.org/grass/ticket/3348.
If you have any suggestions, they are obviously welcome. :slight_smile:
Moritz
