I am a beginner and try to use grass on cygwin.
But I have some trouble in setting projection.
When I create new location, PROJ_INFO and PROJ_UNITS files are not created
Could someone teach me how can I solve this problem, please?
Sorry for my poor English and, maybe, a rudimentary question in advance.
I started cygwin and input “startx” then xwindow opend.
3)I input “grass62” in xwindow. No graphic window was opened. Location name, mapset name, and database name were asked (text mode).
Next, I was asked about coordinate system. I selected B(latlon)
Next, I was asked about the default region. There was no question about datum, so I could not select wgs84 or so.
Then, new location was created but the following message was shown.
LOCATION created
But the PROJECTION information files were not created!
You must run g.setproj successfully before projection software will work
PROJ_INFO and PROJ_UNITS were not created. g.region and g.proj command show nothing.
I input g.setproj, but nothing was occurred though manual of g.setproj said that I will be prompted for the projection name.
Thank you for reading to the end.
I really hope that someone give me some advice.
Thank you.
created
2) I started cygwin and input "startx" then xwindow opend.
3)I input "grass62" in xwindow. No graphic window was opened. Location
4) Next, I was asked about coordinate system. I selected B(latlon)
At this point it /should/ ask you about datums.
5) Next, I was asked about the default region. There was
6) Then, new location was created but the following message was shown.
LOCATION <test> created
software will work
7) PROJ_INFO and PROJ_UNITS were not created. g.region and
8) I input g.setproj, but nothing was occurred though manual of
