[GRASS-user] Trouble installing addons, GRASS 6.4 on SuSE 12.1
Hi!
I'm having trouble installing addons (that recide in svn and need compiling) on GRASS 6.4.2 on my SuSE 12.1 installation.
I first tried through g.extension; that failed; se belowe!
Then I checked out the code from the svn server; and tried to compile. Failure!
It complains that the file grass/gis.h is missimg, se below!
This file is however found in: opt/grass/include/grass/gis.h !
What am I missing here?
Regards
larsf
Errors from compilation:----------------------------------------------------------------------------------------------------------------------
larsf@yoda:~/grassgis/Addons/grass-addons/grass6/raster/r.xtent> make MODULE_TOPDIR=/opt/grass/
/opt/grass//include/Make/Module.make:25: warning: overriding recipe for target `install'
/opt/grass//include/Make/Rules.make:90: warning: ignoring old recipe for target `install'
make OBJ.i686-pc-linux-gnu
make[1]: Entering directory `/home/larsf/grassgis/Addons/grass-addons/grass6/raster/r.xtent'
make[1]: `OBJ.i686-pc-linux-gnu' is up to date.
make[1]: Leaving directory `/home/larsf/grassgis/Addons/grass-addons/grass6/raster/r.xtent'
gcc -I/home/abuild/rpmbuild/BUILDROOT/grass-6.4.2-3.14.i386/opt/grass/include -O2 -I/usr/include/gdal -I/usr/include -DPACKAGE=\""grassmods"\" -I/home/abuild/rpmbuild/BUILDROOT/grass-6.4.2-3.14.i386/opt/grass/include -o OBJ.i686-pc-linux-gnu/at_exit_funcs.o -c at_exit_funcs.c
at_exit_funcs.c:30:23: fatal error: grass/gis.h: Ingen slik fil eller filkatalog (Norwegian; in English: "No such file or directory")
compilation terminated.
make: *** [OBJ.i686-pc-linux-gnu/at_exit_funcs.o] Error 1
Errormessages from G.extension:--------------------------------------------------------------------------------------------------------------------------------------------
(Tue Jul 31 23:20:11 2012)
g.extension -u extension=r.xtent svnurl=http://svn.osgeo.org/grass/grass-addons/grass6
Fetching <r.xtent> from GRASS-Addons SVN (be patient)...
A r.xtent/tools.c
A r.xtent/at_exit_funcs.h
A r.xtent/gt_vector.h
A r.xtent/xtent.c
A r.xtent/r.xtent.001.png
A r.xtent/r.xtent.002.png
A r.xtent/tools.h
A r.xtent/description.html
A r.xtent/r.xtent.003.png
A r.xtent/r.xtent.004.png
A r.xtent/xtent.h
A r.xtent/r.xtent.005.png
A r.xtent/r.xtent.006.png
A r.xtent/r.xtent.007.png
A r.xtent/main.c
A r.xtent/geom.c
A r.xtent/globals.h
A r.xtent/at_exit_funcs.c
A r.xtent/gt_vector.c
A r.xtent/geom.h
A r.xtent/Makefile
Compiling <r.xtent>...
/opt/grass/include/Make/Grass.make:422: warning: overriding
recipe for target `/home/larsf/grassgis/Frosta/larsf/.tmp/yo
da/32363.0/dist.i686-suse-linux/bin'
/opt/grass/include/Make/Grass.make:413: warning: ignoring
old recipe for target `/home/larsf/grassgis/Frosta/larsf/.tm
p/yoda/32363.0/dist.i686-suse-linux/bin'
/opt/grass/include/Make/Module.make:25: warning: overriding
/opt/grass/include/Make/Rules.make:90: warning: ignoring old
  U r.xtent
Sjekket ut revisjon 52489.
mkdir -p /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/bin
mkdir -p /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/include/grass
mkdir -p /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/etc
mkdir -p /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/driver
mkdir -p /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/driver/db
mkdir -p /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/fonts
make[1]: Entering directory `/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/r.xtent'
test -d OBJ.i686-pc-linux-gnu || mkdir -p OBJ.i686-pc-linux-gnu
make[1]: Leaving directory `/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/r.xtent'
gcc '-I/opt/grass/include' '-I/home/larsf/.grass6/addons/include' '-I/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/include' -O2 -I/usr/include/gdal -I/usr/include -DPACKAGE=\""grassmods"\" '-I/opt/grass/include' '-I/home/larsf/.grass6/addons/include' '-I/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/include' -o OBJ.i686-pc-linux-gnu/at_exit_funcs.o -c at_exit_funcs.c
gcc '-I/opt/grass/include' '-I/home/larsf/.grass6/addons/include' '-I/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/include' -O2 -I/usr/include/gdal -I/usr/include -DPACKAGE=\""grassmods"\" '-I/opt/grass/include' '-I/home/larsf/.grass6/addons/include' '-I/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/include' -o OBJ.i686-pc-linux-gnu/gt_vector.o -c gt_vector.c
gcc '-I/opt/grass/include' '-I/home/larsf/.grass6/addons/include' '-I/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/include' -O2 -I/usr/include/gdal -I/usr/include -DPACKAGE=\""grassmods"\" '-I/opt/grass/include' '-I/home/larsf/.grass6/addons/include' '-I/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/include' -o OBJ.i686-pc-linux-gnu/tools.o -c tools.c
gcc '-I/opt/grass/include' '-I/home/larsf/.grass6/addons/include' '-I/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/include' -O2 -I/usr/include/gdal -I/usr/include -DPACKAGE=\""grassmods"\" '-I/opt/grass/include' '-I/home/larsf/.grass6/addons/include' '-I/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/include' -o OBJ.i686-pc-linux-gnu/main.o -c main.c
gcc '-I/opt/grass/include' '-I/home/larsf/.grass6/addons/include' '-I/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/include' -O2 -I/usr/include/gdal -I/usr/include -DPACKAGE=\""grassmods"\" '-I/opt/grass/include' '-I/home/larsf/.grass6/addons/include' '-I/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/include' -o OBJ.i686-pc-linux-gnu/xtent.o -c xtent.c
gcc '-I/opt/grass/include' '-I/home/larsf/.grass6/addons/include' '-I/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/include' -O2 -I/usr/include/gdal -I/usr/include -DPACKAGE=\""grassmods"\" '-I/opt/grass/include' '-I/home/larsf/.grass6/addons/include' '-I/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/include' -o OBJ.i686-pc-linux-gnu/geom.o -c geom.c
gcc '-L/opt/grass/lib' '-L/home/larsf/.grass6/addons/lib' '-L/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/lib' -Wl,--export-dynamic -Wl,-rpath-link,/opt/grass/lib -o /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/bin/r.xtent OBJ.i686-pc-linux-gnu/at_exit_funcs.o OBJ.i686-pc-linux-gnu/gt_vector.o OBJ.i686-pc-linux-gnu/tools.o OBJ.i686-pc-linux-gnu/main.o OBJ.i686-pc-linux-gnu/xtent.o OBJ.i686-pc-linux-gnu/geom.o -lgrass_gis.6.4.2 -lgrass_datetime.6.4.2 -lz -lgrass_datetime.6.4.2 -lgrass_vect.6.4.2 -lgrass_dbmibase.6.4.2 -lgrass_gis.6.4.2 -lgrass_datetime.6.4.2 -lz -lgrass_dbmiclient.6.4.2 -lgrass_dbmibase.6.4.2 -lgrass_gis.6.4.2 -lgrass_datetime.6.4.2 -lz -lgrass_gis.6.4.2 -lgrass_datetime.6.4.2 -lz -lgrass_dgl.6.4.2 -lgrass_dig2.6.4.2 -lgrass_gis.6.4.2 -lgrass_datetime.6.4.2 -lz -lgrass_rtree.6.4.2 -lgrass_gis.6.4.2 -lgrass_datetime.6.4.2 -lz -lgrass_linkm.6.4.2 -lgrass_rtree.6.4.2 -lgrass_dig2.6.4.2 -lgrass_gis.6.4.2 -lgrass_datetime.6.4.2 -lz -lgrass_rtree.6.4.2 -lgrass_dgl.6.4.2 -lgrass_rtree.6.4.2 -lgrass_linkm.6.4.2 -lgrass_dbmiclient.6.4.2 -lgrass_dbmibase.6.4.2 -lgrass_gis.6.4.2 -lgrass_datetime.6.4.2 -lz -lgrass_gis.6.4.2 -lgrass_datetime.6.4.2 -lz -lgrass_dbmibase.6.4.2 -lgrass_gis.6.4.2 -lgrass_datetime.6.4.2 -lz -L/usr/lib -lgdal -L/usr/lib -lgeos -lgeos_c -lgrass_dbmiclient.6.4.2 -lgrass_dbmibase.6.4.2 -lgrass_gis.6.4.2 -lgrass_datetime.6.4.2 -lz -lgrass_gis.6.4.2 -lgrass_datetime.6.4.2 -lz -lgrass_dbmibase.6.4.2 -lgrass_gis.6.4.2 -lgrass_datetime.6.4.2 -lz -lm -lz
make htmlcmd
make /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/docs/html/r.xtent.html HTMLSRC=/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/bin/r.xtent
make[2]: Entering directory `/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/r.xtent'
if [ "/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/bin/r.xtent" != "" ] ; then GISRC=/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/demolocation/.grassrc64 GISBASE=/home/abuild/rpmbuild/BUILDROOT/grass-6.4.2-3.14.i386/opt/grass PATH="/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/bin:$PATH" LD_LIBRARY_PATH="/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/bin:/opt/grass/lib:/opt/grass/lib:/usr/lib/mpi/gcc/openmpi/lib" LC_ALL=C /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/bin/r.xtent --html-description < /dev/null | grep -v '</body>\|</html>' > r.xtent.tmp.html ; true ; fi
/opt/grass/tools/mkhtml.sh r.xtent ; mkdir -p /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/docs/html ; /usr/bin/install -c -m 644 r.xtent.tmp.html /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/docs/html/r.xtent.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/docs/html ; fi done 2> /dev/null ; true
/opt/grass/tools/g.html2man: /opt/grass/tools/g.html2man: is
a directory
make[2]: *** [/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32
363.0/dist.i686-suse-linux/man/man1/r.xtent.1] Error 126
make[1]: *** [mancmd] Error 2
make: *** [cmd] Error 2
ERROR: Compilation failed, sorry. Please check above error messages.
make[2]: Leaving directory `/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/r.xtent'
make mancmd
make /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/man/man1/r.xtent.1 MANSRC=/home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/docs/html/r.xtent.html
mkdir -p /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/man/man1
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.2 sh /opt/grass/tools/g.html2man /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/docs/html/r.xtent.html /home/larsf/grassgis/Frosta/larsf/.tmp/yoda/32363.0/dist.i686-suse-linux/man/man1/r.xtent.1 1
(Tue Jul 31 23:20:18 2012) Command finished (7 sec)
On Tue, Jul 31, 2012 at 11:34 PM, Lars Forseth <lars.forseth@ntebb.no> wrote:
Hi!
Failure!
Please check if there is an additional "grass-devel" package on SuSE
which contains the needed header files. This needs to be installed.
Thanks! Checked, and; grass-devel installed: in opt/grass/include! Regards larsf Files list----------------------------------------------------------------------------
Den 01. aug. 2012 07:31, skrev Markus Neteler:
On Tue, Jul 31, 2012 at 11:34 PM, Lars Forseth [<lars.forseth@ntebb.no>](mailto:lars.forseth@ntebb.no) wrote:
Hi!
Failure!
grass-devel - Development files for grass
/opt/grass/include
/opt/grass/include/Make/Dir.make
/opt/grass/include/Make/Docs.make
/opt/grass/include/Make/Doxygen.make
/opt/grass/include/Make/Html.make
/opt/grass/include/Make/Lib.make
/opt/grass/include/Make/Man.make
/opt/grass/include/Make/Multi.make
/opt/grass/include/Make/Platform.make
/opt/grass/include/Make/Python.make
/opt/grass/include/Make/Script.make
/opt/grass/include/Make/Shlib.make
/opt/grass/include/Make/Stlib.make
/opt/grass/include/grass
/opt/grass/include/grass/CC.h
/opt/grass/include/grass/G3d.h
/opt/grass/include/grass/N_gwflow.h
/opt/grass/include/grass/N_heatflow.h
/opt/grass/include/grass/N_pde.h
/opt/grass/include/grass/N_solute_transport.h
/opt/grass/include/grass/P_datetime.h
/opt/grass/include/grass/P_site.h
/opt/grass/include/grass/Paintlib.h
/opt/grass/include/grass/PolimiFunct.h
/opt/grass/include/grass/V_.h
/opt/grass/include/grass/Vect.h
/opt/grass/include/grass/arraystats.h
/opt/grass/include/grass/bdlg_bm.h
/opt/grass/include/grass/bitmap.h
/opt/grass/include/grass/blas.h
/opt/grass/include/grass/btree.h
/opt/grass/include/grass/cdhc.h
/opt/grass/include/grass/cluster.h
/opt/grass/include/grass/codes.h
/opt/grass/include/grass/colors.h
/opt/grass/include/grass/config.h
/opt/grass/include/grass/dataquad.h
/opt/grass/include/grass/datetime.h
/opt/grass/include/grass/dbmi.h
/opt/grass/include/grass/devlib.h
/opt/grass/include/grass/dgl
/opt/grass/include/grass/dgl.h
/opt/grass/include/grass/dgl/avl.h
/opt/grass/include/grass/dgl/graph.h
/opt/grass/include/grass/dgl/graph_v1.h
/opt/grass/include/grass/dgl/graph_v2.h
/opt/grass/include/grass/dgl/heap.h
/opt/grass/include/grass/dgl/helpers.h
/opt/grass/include/grass/dgl/tavl.h
/opt/grass/include/grass/dgl/tree.h
/opt/grass/include/grass/dgl/type.h
/opt/grass/include/grass/dig_atts.h
/opt/grass/include/grass/display.h
/opt/grass/include/grass/dlg.h
/opt/grass/include/grass/dlg_bm.h
/opt/grass/include/grass/edit.h
/opt/grass/include/grass/form.h
/opt/grass/include/grass/freetypecap.h
/opt/grass/include/grass/geom.h
/opt/grass/include/grass/gis.h
etc etc
However; same result! Regards larsf
Den 01. aug. 2012 09:32, skrev Lars Forseth:
/opt/grass/include
etc etc
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
Hi!
Failure!
