[GRASS-user] Trouble using two screens
Thanks John,
That did the trick. My windows migrate between monitors easily now.
Kurt
On Jan 27, 2008, at 6:55 PM, John C. Tull wrote:
Kurt,
I do the same thing on Leopard, and I do not have any problems. It could be one of the myriad issues with X11 in Leopard. Consider installing the X11 update from below. (I have done that myself.) Let us know if it works for you.
http://trac.macosforge.org/projects/xquartz
John
On Jan 26, 2008, at 9:49 PM, Kurt Springs wrote:
Hi folks,
I was looking at some work this evening using GRASS 6.3. I use two monitors that run as a continuous unit so they act as one monitor. Once GRASS was running, I tried to shift a few GRASS windows out of the way and they seem to get stuck between then two monitors. I can get most of the window onto my second monitor, but I can't move it completely onto the second screen. My other programs are working fine. I recently upgraded to OS X 10.5.1 Leopard. Could this have something to do with it?
Kurt
grass-user mailing list
grass-user@lists.osgeo.org
