[GRASS-user] Trouble when I re-project a vector
  All:
With GRASS 6.4.0 on RedHat Linux I can successfully import a vector shapefile into a Lat-Long GRASS LOCATION. Then I can display the vector file (stream basins) with a color fill — no problems. What I am trying to do is re-project these basins into a Lambert Conic Conformal (LCC) LOCATION. The vector map seemingly re-projects fine, but when display the vector file (stream basins) with a color fill, not all the basins are filled, apparently because no areas are define for the polygons? How do I correct these basin areas?
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
On 01/19/2011 08:51 PM, Thomas Adams wrote:
All:
Tom
Hi Tom:
In order for an area to be a "polygon" in GRASS it must have both a closed boundary and a centroid. When you projected to the LCC location, both the boundaries and the centroids *should* have been projected into the new vector. So your new vector should have the same number of both areas and centroids as the original. ( I guess it's theoretically possible to have a centroid inside a polygon in one projection, and have it fall outside of the polygon when reprojected.)
If you could run v.info on the original vector, and again in the projected mapset, you will be able to see if the number of centroids matches the number of areas. If not, then you'll have to start the digitizer and just add the missing centroids by clicking somewhere inside of those areas (basins) that are missing a centroid.
Micha
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
