[GRASS-user] Trouble with gdal/ogr grass plugin
Hello,
I am having trouble getting the grass plugin for gdal/ogr to work. I ultimately want to get Mapserver and GRASS working together and I am getting stopped at this step. When I run
ogrinfo -ro on some of the spearfish vector data I get
FAILURE:
Unable to open datasource `/home/jd3/grassdata/spearfish60/PERMANENT/vector/tracts' with the following drivers.
  -> GRASS
  -> ESRI Shapefile
  -> MapInfo File
  -> UK .NTF
  -> SDTS
  -> TIGER
  -> S57
  -> DGN
  -> VRT
  -> REC
  -> Memory
  -> BNA
  -> CSV
  -> GML
  -> GPX
  -> KML
  -> GeoJSON
  -> GMT
  -> PostgreSQL
  -> AVCBin
I use the full path, and I made sure the dirs are all readable.
I built all of the components from source.
I am working with GRASS 6.2.3
First I built GDAL version 1.5.1 using --without-grass
Then I built gdal-grass-1.4.3 configuring it like this ./configure --with-gdal=/usr/local/bin/gdal-config --with-grass=/usr/local/grass-6.2.3
The gdal and ogr grass plugins were installed in /usr/local/lib/gdalplugins
When I do gdal_translate --formats, I do indeed see the plugin
-bash-3.00$ gdal_translate --formats
Supported Formats:
  GRASS (ro): GRASS Database Rasters (5.7+)
  VRT (rw+): Virtual Raster ...
Using gdal on the GRASS raster formats gives a similar error.
When I try to access the GRASS data through Mapserver I get :
msDrawMap(): Image handling error. Failed to draw layer named 'Example2'.
msOGRFileOpen(): OGR error. Open failed for OGR connection `/home/jd3/grassdata/spearfish60/PERMANENT/vector/t_tracts'. File not found or unsupported format.
This is the Mapserver I am working with
-bash-3.00$ ./mapserv -v
MapServer version 4.10.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SW
F OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CL
IENT SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS INPUT=TIFF INPUT=E
PPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Could all this be due to a mismatch of versions between GDAL and GRASS? I have made sure that I am indeed calling the versions that I think I am by using the command 'which'.
Ultimately, I want to display GRASS data in a web interface. Any suggestions would be greatly appreciated.
John David Overton
On Tue, 08 Jul 2008 15:44:02 -0400
John Overton <jd3@renci.org> wrote:
Hello,
FAILURE:
following drivers.
try ogrinfo -ro /home/jd3/grassdata/spearfish60/PERMANENT/vector/tracts/head
and
gdalinfo /home/jd3/grassdata/spearfish60/PERMANENT/cellhd/<mapname>
that should work.
regards,
Otto
  -> GRASS
  -> ESRI Shapefile
  -> MapInfo File
  -> UK .NTF
  -> SDTS
  -> TIGER
  -> S57
  -> DGN
  -> VRT
  -> REC
  -> Memory
  -> BNA
  -> CSV
  -> GML
  -> GPX
  -> KML
  -> GeoJSON
  -> GMT
  -> PostgreSQL
  -> AVCBin
Supported Formats:
OUTPUT=SW
SUPPORTS=WMS_CL
INPUT=E
John David Overton
