I am using GRASS 6.4.1 (2011) on Mac (mac os x 10.7.3). Generally I am
running GRASS without any trouble but calling r.terraflow from the command
line generates the following error comments:
MM error: limit =0B. allocating 16B. limit exceeded by 24B.
Assertion failed: (0), function operator new, file mm.cc, line 326.
Abort trap: 6
using the gui generates preety much the same output:
tree = etree.fromstring(getInterfaceDescription(cmd))
File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpyt
hon/gui_modules/menuform.py", line 1973, in
"Details: %s") % (cmd, cmderr)
gui_modules.gcmd
GException
Unable to fetch interface description for command
'r.terraflow'. Details: MM error: limit =0B. allocating 16B.
line 326.
Does anybody knows whats going wrong here.
Thanks in advance
Abort trap: 6
It would help a lot if you could provide exact the command line used
to invoke r.terraflow. A first guess is that the memory option was set
to something higher than 2048, because r.terraflow in 6.4.1 can only
use a maximum of 2GB of memory. Since r.terraflow is very efficient in
handling temporary data, you could just as well leave out the memory
option (default is 300MB). Alternatively, you can use r.watershed
which produces more realistic results.
Markus M
gui_modules.gcmd
GException
line 326.
Thanks in advance
On Mon, Apr 9, 2012 at 8:05 PM, tomte <tomte.tumetot@gmx.ch> wrote:
Dear folks,
Abort trap: 6
Hm, 576 cells is really not a lot, r.terraflow should work. I am still
puzzled about the "MM error: limit =0B" error. Can you try to set the
memory option to 200 and report what happens? Alternatively, try
r.watershed.
