File-Import Vector map-import various data using OGR-result"Error .shx file. unable or corrupt:.
shape-file-defintion (see ESRI Shapefile Technical Description: http://www.esri.com/library/whitepapers/pdfs/shapefile.pdf) :
.shx - the file that stores the index of the feature geometry
so a .shx-file is part of a shape-file.
for a shapefile you should use the v.in.ogr-tool and choose name_of_the_shapefile.shp and not the .shx-file.
a dxf-file has the extension .dxf. if you want to import this kind of data use v.in.dxf.
Helmut
___________________________________________________________
WEB.DE DSL: Internet, Telefon und Entertainment für nur 19,99 EUR/mtl.!
http://produkte.web.de/go/02/
