[GRASS-user] troubles with i.landsat.rgb and d.rgb
Hello-
I have used r.ing.dal to import different Landsat TIFF images, and am now
trying to superimpose red, green, and blue spectral bandsto get "real
colour" images.
I am under the impression that I need to use i.landsat.rgb to auto-balance
the colours of the LANDSAT images I am using. I am using a PC, and when I
run the command:
i.landsat.rgb red=020.020.2000.055_B30 green=020.020.2000.055_B20
blue=020.020.2000.055_B10
a microsoft windows window pops up that informs me " r.univar.exe has
stopped working- a problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available".
As long as I continue to run the i.landsat.rgb command, this window
continues to pop up.
Have I made a mistake somewhere??
Also, once (if?) I do get i.landsat.rgb to work, will the map display window
automatically show me the superimposed images??
Also, I have tried just running d.rgb on the same images:
d.rgb red=020.020.2000.103_B30 blue=020.020.2000.103_B20
green=020.020.2000.103_B10
with results:
PNG: GRASS_TRUECOLOR status: TRUE
PNG: collecting to file: F:/grassdata/path20/PERMANENT/.tmp/412.0.ppm,
     GRASS_WIDTH=535, GRASS_HEIGHT=484
but nothing shows up in my map display window. How do I display the results
of this??
I am very new to GRASS, so any advice would be much appreciated. Thanks
very much for the help,
Renae Mackas
View this message in context: http://n2.nabble.com/troubles-with-i.landsat.rgb-and-d.rgb-tp2316681p2316681.html
colour" images.
auto-balance the colours of the LANDSAT images I am using.
you do not "need" to use i.landsat.rgb, it just helps brighten things up
if the image comes out rather dark. example:
  http://bambi.otago.ac.nz/hamish/grass/landsat/
I am using a PC,
does that mean you are running MS Windows? native or cygwin version?
(sorry to be overly pedantic, but consider that many run linux on a PC,
and that historically many/most? GRASS users use some flavour of Linux)
and when I run the command:
Windows will close the program and notify you if a solution is vailable".
this window continues to pop up.
can you run "r.univar 020.020.2000.055_B10" from the command prompt?
don't really know. might be an install problem.
can you view the scene ok in QGIS? (www.qgis.org)
window automatically show me the superimposed images??
no. if you are currently viewing the layers you have to do a "hard"
redraw as the GUI isn't aware that the colors have changed behind its
back and the existing view may be partially cached.
if this is the native build d.rgb shouldn't work from the command prompt,
as there are no xmon to draw to (d.mon + UNIX's X-Windows). Instead use
the 'Add RGB or HIS layer' button from the GIS manager.
the cygwin version uses X-Windows (aka X11) and so allows xmons.
good luck,
Hamish
Thanks for your input, and sorry for the delayed response Hamish, I've been
away for the last while and haven't had much chance to work with Grass.
colour" images.
The reason that I wanted to try and use i.landsat.rgb is that when I have
been doing r.composite with the Landsat images, the resulting composite
images come out with a coloured tinge to them (I am putting together
images of sea ice formations, and most r.composite images come out with a
pinkish/purple tinge). I thought I might be able to avoid this using
i.landsat.rgb. Perhaps this was an incorrect assumption?
I am using a PC, using the native version.
Yes, I am using MS windows, using the native version
Yes, I could run this.
How do I do a "hard" redraw to be able to see the result of i.landsat.rgb?
What I ultimately want is a mosaic image of multiple Landsat images. If I
do end up using i.landsat.rgb, do end up doing the "hard redraw" with my
final mosaiced image, or do I have to do it seperately with each image
that I want to put into the mosaic?
I tried using the button, and it displayed well, thank you.
good luck,
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
View this message in context: http://n2.nabble.com/troubles-with-i.landsat.rgb-and-d.rgb-tp2316681p2483705.html
