Gabriel Zorello Laporta wrote:
I am using ArcInfo Workstation and Grid in order to to produce Gaussian
functions of elevation from a DEM with minimum value at 800m, as follow:
elev_x800 = elev90 - 800
elev_x800sq = pow(elev_x800, 2)
elev_x800sqn = -1 * elev_x800sq
elev_x800sqnd = elev_x800sqn / 500000
elev_x800exp = exp(elev_x800sqnd)
elev_x800gaus = elev_x800exp * 0.000798
elev_x800gi = (elev_x800gaus * -11330) + 10.044
I was wondering how to apply that in GRASS (because I want to move towards
Open Software). Can you help me?
You should be able to use those exact same expressions in r.mapcalc,
e.g.
r.mapcalc <<EOF
EOF
The above will write out each step as a map; if you only need the
final result (elev_x800gi), you can omit all of the intermediate steps
and use e.g.:
r.mapcalc "elev_x800gi = (exp(-((elev90 - 800)^2) / 500000) * 0.000798 * -11330) + 10.044"
Or, if you want to keep the expressions in the above form but only
want the last one written out as a map, use eval(), e.g.:
r.mapcalc <<EOF
eval(elev_x800 = elev90 - 800,\
elev_x800sq = pow(elev_x800, 2),\
elev_x800sqn = -1 * elev_x800sq,\
elev_x800sqnd = elev_x800sqn / 500000,\
elev_x800exp = exp(elev_x800sqnd),\
elev_x800gaus = elev_x800exp * 0.000798)
EOF
