[GRASS-user] Tutorial & help needed::join tables (which are stored in postgres) and export result
Dear list,
I am still testing, what kind of database I should use for my work with
GRASS/QGIS. As my experiences with sqlite3 where not that positive (large
datasets took very much time to be read into sqlite), I started working with
postgres (and my first impression is that it's far more faster). dbf is
quick, but does not offer me the possibility to perform "table-join", which I
need every day.
I am not that experienced with pg, therefore, I would like to ask you folks
some questions about "daily GIS work with postgres in GRASS":
* How can I join pg-tables in GRASS, can I export a joined theme to make it
permanent (for example, I would like to create a shapefile out of it which
contains all information of the join)
* Does anybody has experience with pg-frontends like knoda and pg_admin?
Working with tables on the command-line is hard for people who used *other
programmes* before :wink:
* what about large datasets: shapefiles with *qix-files seem to be loaded
faster compared the same theme in GRASS with its attributes in postgres
* tutorials available for this pg-stuff inside of GRASS?
Any comments / hints are greatly appreciated!
Best regards,
Wolfgang
Hey Wqual,
I am starting to work with PGSQL/POSTGIS with GRASS and learning as I
go. Welcome to the club.
First I would encourage you to check out the estensive documentation
online... This might be what you need... Here are the docs on how to
join tables
http://www.postgresql.org/docs/8.1/static/tutorial-join.html
How to do it in grass? Not sure, I'm learning the CLI to understand how
PG works. I'm no programer, I just learn the stuff I need to.
However, that said if GRASS can pass and exploit SQL commands then I am
sure this is possible. If it is not then getting some dicussion going on
the list is a great first step.
As for tutotirals, that's why I'm learning so I can create a hands on
tutorial... So perhaps we can get some people working together on this
using a common dataset.
Check out the http://grass.itc.it/community/sqlgrasslist.html for maybe
some more help. I have not ventured there yet so no idea if they can
help, but it makes sense.
Check out this SQL primer for grass 5.0
http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass/src.garden/grass
.postgresql/tutorial/index.html
As for front ends I have some experience with Pgadmin, but most books
from the library use the CLI so PGADMIN is on hold right now... But if
you are used to ORACLE/SDE combos it is verry similar, at least in the
way of layout and permissions.
Have not done becnh marking on file sizes and formats.
Hope some of this helps.
-----Original Message-----
[mailto:grassuser-bounces@grass.itc.it] On Behalf Of wqual
Sent: August 3, 2006 08:30
To: grassuser@grass.itc.it
Subject: [GRASS-user] Tutorial & help needed::join tables (which are
storedin postgres) and export result
Dear list,
(large datasets took very much time to be read into sqlite), I started
working with postgres (and my first impression is that it's far more
faster). dbf is quick, but does not offer me the possibility to perform
"table-join", which I need every day.
folks some questions about "daily GIS work with postgres in GRASS":
it permanent (for example, I would like to create a shapefile out of it
which contains all information of the join)
*other
loaded faster compared the same theme in GRASS with its attributes in
postgres
Best regards,
Wolfgang
grassuser mailing list
Quick reply, as I have not completely finished these documents --- but feel
free to browse them here:
http://casoilresource.lawr.ucdavis.edu/drupal/node/264
there are some sample postgis queries which illustrate the use of spatial
operations, attribute joins, and such.
I am hoping to have a working set of my notes on interacting with USDA-NCSS
soil survey (SSURGO and STATSGO) within PostGIS, GRASS, etc.
I'll post an update when I make some changes.
Dylan
On Thursday 03 August 2006 05:30, wqual wrote:
Dear list,
with postgres (and my first impression is that it's far more faster). dbf
is quick, but does not offer me the possibility to perform "table-join",
Best regards,
Wolfgang
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Is it possible for GRASS to Write to postgres/postgis... I seem to
remember something about read only and then you write to local grass.
Can you clarify?
[mailto:grassuser-bounces@grass.itc.it] On Behalf Of Dylan Beaudette
Sent: August 3, 2006 14:03
Cc: wqual
Subject: Re: [GRASS-user] Tutorial & help needed::join tables (which
arestored in postgres) and export result
feel free to browse them here:
spatial operations, attribute joins, and such.
USDA-NCSS soil survey (SSURGO and STATSGO) within PostGIS, GRASS, etc.
Dylan
Dear list,
with GRASS/QGIS. As my experiences with sqlite3 where not that
positive (large datasets took very much time to be read into sqlite),
I started working with postgres (and my first impression is that it's
far more faster). dbf is quick, but does not offer me the possibility
to perform "table-join", which I need every day.
make it permanent (for example, I would like to create a shapefile out
of it which contains all information of the join)
pg_admin?
*other
postgres
Best regards,
Wolfgang
Dylan Beaudette
Soils and Biogeochemistry Graduate Group University of California at
Davis
530.754.7341
How about using OGR as the go-between:
v.out.ogr in=xxx dsn="PG ...."
ogr2ogr "PG ...." grass/location/mapset/vector/...
here is a prototype for exporting from postgis to shapefile, but obviously it
could go between any OGR supported format (i think)
ogr2ogr file.shp PG:"dbname=ssurgo_combined user=xxxx password=xxxx host=xxxx"
tablename
cheers,
Dylan
Can you clarify?
Cc: wqual
Dylan
> Dear list,
pg_admin?
> *other
> postgres
> Best regards,
> Wolfgang
Dylan Beaudette
Davis
530.754.7341
Dylan Beaudette
530.754.7341
wqual wrote:
Dear list,
I am still testing, what kind of database I should use for my work with GRASS/QGIS. As my experiences with sqlite3 where not that positive (large datasets took very much time to be read into sqlite), I started working with postgres (and my first impression is that it's far more faster). dbf is quick, but does not offer me the possibility to perform "table-join", which I need every day. I am not that experienced with pg, therefore, I would like to ask you folks some questions about "daily GIS work with postgres in GRASS":
You don't have to do the work in GRASS (although you can use db.execute to send any SQL-query you like to your database backend. If you prefer to work with a graphical then you are free to do so.
BTW I find it easiest to just use views, instead of new tables, joining two existing tables. That way you reduce the number of actual tables to a strict minimum. And as a side-effect you don't erase a table when you erase the map.
You can then use v.db.connect to connect the map to any table or view you wish, as long as it has a column containing the category codes of the map.
Just watch out: when you erase a map, the table it is linked to is also erased.
permanent (for example, I would like to create a shapefile out of it which contains all information of the join)
When you use v.out.ogr to export a GRASS map to shape, it will create the corresponding dbf file on the basis of the table/view linked to the map. So, yes, you can.
* Does anybody has experience with pg-frontends like knoda and pg_admin? Working with tables on the command-line is hard for people who used *other programmes* before :wink:
Sorry, whenever I tried, I found going back to psql much faster...
* what about large datasets: shapefiles with *qix-files seem to be loaded faster compared the same theme in GRASS with its attributes in postgres
What do you mean by 'loaded' ? How are you loading the shapefiles ?
Intros:
http://grass.itc.it/grass61/manuals/html61_user/databaseintro.html
http://grass.itc.it/grass61/manuals/html61_user/sql.html
Tutorial:
http://www.gdf-hannover.de/lit_html/grass60_v1.2_en/node49.html
Moritz
