[GRASS-user] tweak r.buffer to incorporate dampening function
Greetings,
So I have some points which represent the estimated locations of Wifi networks
in my neighborhood. Thus far I have been able to make some fun maps which
estimate the "density" of signal based on a couple simple assumptions.
(http://169.237.35.250/~dylan/temp/sycamore-wifi-range-ogr_python.jpg)
However, this method assumes a constant, circular coverage area. I would like
to model propagation of the wifi signal (assuming no interference from trees,
etc) using a simple equation realting relative signal strength as a function
of distance from the signal source.
I have taken a quick peek at the source for r.buffer, and am wondering how
difficult it would be to modify it such that the module would optionally
write cells based on the distance from the starting point, defined by some
function.
anyone familiar with r.buffer?
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
there was a discussion about similar topic some time a go
[GRASS-user] [GRASSLIST:1081] Sediment dispersal modeling
It would be nice if there could be some module that could simulate flow using
user's defined equation. No, I don't have time right now to code it. :wink:
Maris.
On Wednesday 06 September 2006 22:07, Dylan Beaudette wrote:
Greetings,
networks in my neighborhood. Thus far I have been able to make some fun
maps which estimate the "density" of signal based on a couple simple
assumptions.
like to model propagation of the wifi signal (assuming no interference from
trees, etc) using a simple equation realting relative signal strength as a
function of distance from the signal source.
function.
Answering my own question, looks like a combination of r.cost and r.mapcalc
did the trick...
details at 11 !
Dylan
On Wednesday 06 September 2006 13:00, Māris Nartišs wrote:
using user's defined equation. No, I don't have time right now to code it.
:wink:
Maris.
> Greetings,
> assumptions.
> from trees, etc) using a simple equation realting relative signal
> strength as a function of distance from the signal source.
> how difficult it would be to modify it such that the module would
> optionally write cells based on the distance from the starting point,
> defined by some function.
> Cheers,
grassuser mailing list
grassuser@grass.itc.it
Dylan Beaudette
530.754.7341
As promised, some details on getting an estimated power level as a function of
distance from network center: implemented with r.cost and r.mapcalc
http://casoilresource.lawr.ucdavis.edu/drupal/node/288
cheers,
Dylan
did the trick...
details at 11 !
Dylan
> Hi,
> it. :wink:
> Maris.
> > Greetings,
> > assumptions.
> > would like to model propagation of the wifi signal (assuming no
> > interference from trees, etc) using a simple equation realting relative
> > signal strength as a function of distance from the signal source.
> > Cheers,
Dylan Beaudette
530.754.7341
