[GRASS-user] two questions on setting a new layer for for a vector
I’m having some doubts on the layer mechanism.
Two questions in this point.
  1. Creating a new layer (ie a new connection between a vector and a DB table)
    I’ve imported a vector (rivers) through v.in.ogr, then I’ve cloned the original table:
db.copy from_table=rivers to_table=rivers_clone
I’ve created a new connection:
v.db.connect map=rivers table=rivers_clone layer=2
At this point I supposed that the last command had created all the needed structures and fields for the new layer (2), but if I print the categories:
v.category input=rivers layer=2 option=print
no categories are displyed (while they are listed if I choose layer 1)
Question: I thought that a new connection used the same vector categories, but it seems I was wrong. How to make the layer 2 use the same vactor categories from layer 1?
  1. I haven’t understood the purpose of v.category chlayer option.
    The manual says that the commands change layer numbers. If I understand it correctly, it changes the numbering of the vector-db connections, right? Whatever it means I wonder why a new vector is created. If I have a vector with layers 1,2 I thought that chlayer let me swap the numbers, but if it creates a new vector it doesn’t change the layer numbers, it creates a new layer with the new layer number… I’m confused
Help :slight_smile:
thx,
giovanni
I’ve solved my needs about the creation of a new layer, but I feel that the mechanism a bit counter-intuitive.
A new layer can be created only through an intemediary vector
v.category input=rivers output=rivers_tmp layer=2
g.remove vect=rivers
g.rename vect=rivers_tmp,rivers
Directly creating a new connection on a new layer produces the new layer, but the categories are not attached:
and the vector seems to have a new layer, but it cannot be used.
I see the same results if I create a new layer through the wxGUI (vector attributes window → new layer). A new layer is shown, but it cannot be used (eg cannot be displayed). I will open a ticket on this.
giovanni
2011/11/20 G. Allegri <giohappy@gmail.com>
Help :slight_smile:
thx,
giovanni
On 22/11/11 08:44, G. Allegri wrote:
I've solved my needs about the creation of a new layer, but I feel that
A new layer can be created *only* through an intemediary vector
and the vector *seems* to have a new layer, but it cannot be used.
attributes window -> new layer). A new layer is shown, but it cannot be
Please note that this is not a bug, but apparently a misunderstanding of how the layer mechanism works.
Layers are not a database connection tool. The closest I can get in terms of a short definition of layers is that they are a tool for thematically grouping objects in a vector map. For example, you can have a series of field boundaries in a map and none of them have a category value in layer 1 as layer 1 is 'fields' and the category values of fields (= polygons) are with the centroids. However, if some of these boundary lines are also hiking paths, you can give them category numbers in layer 2 and thus layer 2 becomes the thematic layer "hiking paths". Another example would be weather stations for which you have a whole battery of measures every day and instead of putting them all into one attribute table, you wish to have one table per day. You could then create one layer per day and each station would then have to have a category number in each layer.
Any layer can, but does not have to, be connected to an attribute table. For any element in the map which has a category number in that layer, the system will then look into the attribute table and search for this category number in the key column. If that category number is not present in that column, then there are no attributes for that element.
So:
- You create a link between a layer and a table, but if no element in the map has a category value in that layer, then your link is useless. In other words, a layer only makes sense when you actually give category values to elements in your map in that layer.
- Layers can be useful without tables, and so one probably should see these two concepts (layers and database connections) as separate, though obviously linked.
The fact that v.category creates a new map with the results of the manipulation of the category values is probably a welcome security. If you delete all your category values by accident (e.g. you forget to specify the type when you want to delete category values from boundaries, but not centroids), the fact that the result is a new map reduces the chances for catastrophe. If you a sure that you will never make a mistake, you can always script the two steps (no need for the g.remove):
g.rename vect=rivers_tmp,rivers --o
I agree that it would be helpful to have an opion in v.category to copy the values from one layer to another (i.e. something like option=copy layer=2 sourcelayer=1).
Moritz
