Yes, I guess, I've started grass using --text option because I'm interested in using my own "sh". But always find problems to execute d.mon start=wx1
Something to add from my last email. I've also installed QGIS and its GRASS toolbox. Then d.mon works using the QGIS console, I mean from the GRASS toolbox in QGIS...
Thanks
Javier Álvarez Rodríguez
Coordinador de Programa Técnico Científico
Javier.alvarez@cedex.es
Centro de Estudios Hidrográficos
Paseo Bajo de la Virgen del Puerto, 3. 28005 Madrid
Tel.: (+34) 91 335 79 38
-----Mensaje original-----
De: Anna Petrášová [mailto:kratochanna@gmail.com]
Enviado el: lunes, 18 de septiembre de 2017 17:34
Para: Javier Álvarez Rodríguez
CC: grass-user@lists.osgeo.org
Asunto: Re: [GRASS-user] unable to execute d.mon
Have you started GRASS at all? You can normally run these commands only from a running GRASS session.
Anna
On Mon, Sep 18, 2017 at 9:41 AM, Javier Álvarez Rodríguez <Javier.Alvarez@cedex.es> wrote:
Dear people,
I wonder why I can’t execute d.mon in my grass72. I’m working on
fedora 26 (and GNOME) and tried to install grass72. I have installed
the source code and previously installed the whole set of libraries
you required, but I can’t open monitors. When typing d.mon or even
g.gui, I receive the following message, “Unable to execute the
command”. Do you have any idea to make it work?
Thanks in advance
grass-user mailing list
