Hi, dear members: In order to avoid the
ERROR: Unable to open element file <> for
<WIND >
On grass 7.8.2-1 ubuntu version, I tried to compile the updated version (7.8.3dev). It seems that everything works in compilation step, but when I try to use nvis (3d View), I got this message on console:
Starting 3D view mode...
NotImplementedError
The above exception was the direct cause of the following
exception:
File "/home/kenneth/Descargas/grass78/grass-7.8.git_src_sn
apshot_2020_04_25/dist.x86_64-pc-linux-
gnu/gui/wxpython/mapdisp/toolbars.py", line 244, in
OnSelectTool
self.parent.AddNviz()
gnu/gui/wxpython/mapdisp/frame.py", line 392, in AddNviz
lmgr=self._layerManager)
gnu/gui/wxpython/nviz/mapwindow.py", line 103, in __init__
glcanvas.GLCanvas.__init__(self, parent, id,
attribList=attribs)
SystemError
<method-wrapper '__init__' of GLWindow object at
0x7f8e38a41f78> returned a result with an error set
What am I doing wrong? I follow the steps at: https://grasswiki.osgeo.org/wiki/Compile_and_Install and https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu My compilation parameters were:
# "configure" source code for local machine (checks for CPU type etc):
MYCFLAGS='-O2 -fPIC -fno-common -fexceptions -std=gnu99 -fstack-protector -m64 -g -Wall'
#MYCXXFLAGS=''
MYLDFLAGS='-Wl,--no-undefined -Wl,-z,now'
LDFLAGS="$MYLDFLAGS" CFLAGS="$MYCFLAGS" CXXFLAGS="$MYCXXFLAGS" ./configure \
--with-cxx \
--enable-largefile \
--with-proj --with-proj-share=/usr/share/proj \
--with-gdal=/usr/bin/gdal-config \
--with-python \
--with-geos \
--with-sqlite \
--with-nls \
--with-zstd \
--with-pdal \
--with-cairo --with-cairo-ldflags=-lfontconfig \
--with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" \
--with-wxwidgets \
--with-fftw \
--with-motif \
--with-opengl-libs=/usr/include/GL \
--with-postgres=yes --with-postgres-includes="/usr/include/postgresql" \
--without-netcdf \
--without-mysql \
--without-odbc \
--without-openmp \
--without-ffmpeg
My environment is:
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.4 LTS
Release: 18.04
Codename: bionic
geos-config --version
3.8.0
gdal-config --version
3.0.4
proj
Rel. 7.0.0, March 1st, 2020
flex --version
flex 2.6.4
python --version
Python 3.6.9
gcc --version
gcc (Ubuntu 9.3.0-11ubuntu0~18.04.1) 9.3.0
glxinfo | grep "OpenGL version"
OpenGL version string: 3.3.0 NVIDIA 340.108
Thank you for your help.
