[GRASS-user] Unable to link to postgis/postgresql
Hi list,
I hope this is not a duplicate, but I could not find any solution on the
web by know.
I trying to connect to a remote postgresql database, without success.
What I have done:
1)
db.connect driver=pg
database="host=vmhydro27,dbname=cedim_rfra,port=5432"
2)db.login driver=pg database=cedim_rfra user=sluedtke password=#####
host=vmhydro27
3) db.tables -p
DBMI-PostgreSQL driver error:
Connection failed.
could not connect to server: No such file or directory
        Is the server running locally and accepting
        connections on Unix domain socket
"/var/run/postgresql/.s.PGSQL.5432"?
Connection failed.
ERROR: Unable to open database <host=vmhydro27,dbname=cedim_rfra,port=5432>
I tried all drivers (odbc, ogr, pg) that made sense to me, no success.
It is no problem to connect QGIS, R and python to this db and visualize
the data.
I am using Kubuntu 16.04 with GRASS 7.04.
[I] /u/bin  apt-cache show grass
                            Mon 12 Sep 2016 13:20:37 CEST
Package: grass
Status: install ok installed
Priority: optional
Section: metapackages
Installed-Size: 33
Maintainer: Debian GIS Project <pkg-grass-devel@lists.alioth.debian.org>
Architecture: all
Version: 7.0.4-1~xenial2
Replaces: grass7, grass70
Provides: grass7, grass70
Depends: grass-core, grass-gui
Recommends: grass-doc
Suggests: grass-dev
Conflicts: grass7, grass70
Description: Geographic Resources Analysis Support System (GRASS GIS)
Commonly referred to as GRASS, this is a Geographic Information
System (GIS) used for geospatial data management and analysis,
image processing, graphics/map production, spatial modeling, and
visualization. GRASS is currently used in academic and commercial
settings around the world, as well as by many government agencies
and environmental consulting companies.
Install this virtual package to get a full GRASS system.
Description-md5: 927e5df9adc0c220121824a1dcc21063
Homepage: http://grass.osgeo.org/
I am able to get info of a certain layer using ogrinfo with the
connection string.
Any help is appreciated.
Stefan
Le Mon, 12 Sep 2016 13:22:29 +0200,
Stefan Lüdtke <sluedtke@gfz-potsdam.de> a écrit :
Hi list,
the web by know.
What I have done:
1)
As this is the standard port, you could try without the port=5432 part
in the database definition string.
host=vmhydro27
Try with either no database info in the db.login call, or with the port
parameter set, i.e.
db.login user=sluedtke password=######
or
host=vmhydro27 port=5432
Moritz
Hi Moritz,
thanks for the hints but non of them worked.
As additional info. I have configured a couple of odbc connections I use
in R. Using these connections in GRASS do not give an error but do not
show any tables. Those odbc connections work as well from libreoffice.
That's it from my side so far.
Stefan
Hi list,
the web by know.
What I have done:
1)
host=vmhydro27
parameter set, i.e.
or
Moritz
Stefan Lüdtke
Section 5.4- Hydrology
Phone: +49(0)331-288-2821
Fax: +49(0)331-288-1570
Email: sluedtke@gfz-potsdam.de
___________________________________________
Helmholtz Centre Potsdam
GFZ German Research Centre for Geosciences
Foundation under public law of the federal state
of Brandenburg
Telegrafenberg, D-14473 Potsdam
Hi list,
Always the same problem with a remote Postgresql connection, with grass 7.0.4 and above (7.2 and 7.3). With grass 7.0.0, the connection to postgresql is perfect. I don’t try with 7.0.1, 7.0.2 and 7.0.3
All my other soft using Postgresql work fine (i.e. pgadmin, odoo, caldav, carddav, libreoffice, …)
The problem is the for all the PC on my network (server under Centos 7, workstations under Fedora 19, 21 or 22)
(attachments)
Le 12/09/16 13:22, Stefan Lüdtke a écrit :
Hi list,
web by know.
What I have done:
1)
host=vmhydro27
3) db.tables -p
Connection failed.
Connection failed.
the data.
Package: grass
Priority: optional
Installed-Size: 33
Maintainer: Debian GIS Project [<pkg-grass-devel@lists.alioth.debian.org>](mailto:pkg-grass-devel@lists.alioth.debian.org)
Architecture: all
Suggests: grass-dev
Homepage: [http://grass.osgeo.org/](http://grass.osgeo.org/)
connection string.
Stefan
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
Benoit André
Directeur - Gérant
benoit.andre@bcgeol.be
Tel. | +32 475 61 84 94
skype | benoit_andre_bcg
Voir le profil de Benoit André sur LinkedIn
BCG SPRL
Tél. | +32(0)81 58 26 11
Fax | +32(0)81 58 26 12
Chemin de la Foliette, 4 Bte 2
B-5000 - Namur
www.bcgeol.be - plan d’accès
BCG LOGO
Suivez-nous sur Lien LinkedinLien Facebook
Allons plus loin dans le respect de l’environnement : N’utilisons que des produits sans empreinte écologiqueLogo Modere
This really is a serious issue.
Would it be possible for you to provide a reproducible example ? Ideally
starting out from the North Caroline data. Something that creates a new
postgresql database, redefined db.connect to link to that, g.copy a few
maps and then see if the connection problem still happens ?
Ideally this should go into a bug ticket and IMHO it should definitely
be a blocker for the upcoming releases as I would consider this basic
functionality.
Moritz
Le Wed, 14 Sep 2016 11:22:57 +0200,
Benoit ANDRE <benoit.andre@bcgeol.be> a écrit :
Hi list,
connection to postgresql is perfect. I don't try with 7.0.1, 7.0.2
and 7.0.3
caldav, carddav, libreoffice, ...)
> Hi list,
> on the web by know.
> success.
> What I have done:
> 1)
> password=##### host=vmhydro27
> 3) db.tables -p
> Connection failed.
> Connection failed.
> success.
> visualize the data.
> Package: grass
> Priority: optional
> Installed-Size: 33
> <pkg-grass-devel@lists.alioth.debian.org> Architecture: all
> Suggests: grass-dev
> GIS) Commonly referred to as GRASS, this is a Geographic Information
> connection string.
> Cheers,
> Stefan
2016-09-12 13:22 GMT+02:00 Stefan Lüdtke <sluedtke@gfz-potsdam.de>:
1)
host=vmhydro27
please try out:
db.connect driver=pg database=edim_rfra
Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
2016-09-14 13:06 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
I tested with 7.0.5.svn:
db.connect dri=pg datab=mydb
db.login dri=pg datab=mydb host=myhost user=myuser pass=mypw port=5432
db.tables -p
works. Could you try to enable debug message and post here relevant information:
g.gisenv set=debug=3
db.tables -p 2>&1 | grep open_database
(be aware that the log will contain all login information including
real password - good idea to change it before post here :slight_smile:
Ma
Martin Landa
2016-09-14 13:40 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
hm, with 7.0.4 you will not get relevant info, I fix debug message in
r69481. Could you try 7.0.5svn? You should get:
D3/5: db_driver_open_database(): host = myhost, port = 5432, options =
(null), tty = (null), dbname = mydb, user = myuser, password = mypw
schema = (null)
Ma
Martin Landa
Hi Martin,
Here is my log :
.-(/disques/divers/linux-1/archive/GIS/grass/grass-7.0/pyrite/grass-7.0.svn_src_snapshot_2016_09_10)------------------------------------------------------------(benoit@pyrite)-
--> db.connect dri=pg datab=administration D1/3: G_set_program_name(): db.connect D2/3: G_file_name(): path = /disques/grassdata/BCG_V7/benoit D2/3: dbDbmscap(): opendir [/disques/divers/linux-1/archive/GIS/grass/grass-7.0/pyrite/grass-7.0.svn_src_snapshot_2016_09_10/dist.i686-pc-linux-gnu/driver/db/] D3/3: db_get_login(): drv=[pg] db=[administration] D3/3: read_file(): DB login file = </home/benoit/.grass7/dblogin> .-(/disques/divers/linux-1/archive/GIS/grass/grass-7.0/pyrite/grass-7.0.svn_src_snapshot_2016_09_10)------------------------------------------------------------(benoit@pyrite)- → db.login dri=pg datab=administration host=192.168.1.200 user=benoit port=5432
D1/3: G_set_program_name(): db.login
D3/3: db_set_login(): drv=[pg] db=[administration] usr=[benoit] pwd=[(null)] host=[192.168.1.200] port=[5432]
D3/3: write_file(): DB login file = </home/benoit/.grass7/dblogin>
`–> db.tables -p
D1/3: G_set_program_name(): db.tables
D1/3: db_d_init_error(): PostgreSQL
D3/3: ret = 3 : drv=[pg] db=[administration] usr=[benoit] pwd= host=, port=
D3/3: db_driver_open_database(): driver=pg database definition = ‘administration’
D3/3: parse_conn: ‘administration’
D3/3: db_driver_open_database(): host = (null), port = (null), options = (null), tty = (null), dbname = administration, user = (null), password = (null), host = (null), port = (null) schema = (null)
DBMI-PostgreSQL erreur de pilote :
Connection failed.
n’a pas pu se connecter au serveur : Aucun fichier ou dossier de ce type
Le serveur est-il actif localement et accepte-t-il les connexions sur la
socket Unix « /var/run/postgresql/.s.PGSQL.5432 » ?
Connection failed.
ERREUR :Unable to open database
--> db.tables -p 2>&1 | grep open_database D3/3: db_driver_open_database(): driver=pg database definition = 'administration' D3/3: db_driver_open_database(): host = (null), port = (null), options = (null), tty = (null), dbname = administration, user = (null), password = (null), host = (null), port = (null) schema = (null) .-(/disques/divers/linux-1/archive/GIS/grass/grass-7.0/pyrite/grass-7.0.svn_src_snapshot_2016_09_10)------------------------------------------------------------(benoit@pyrite)-
(attachments)
Le 14/09/16 13:40, Martin Landa a écrit :
2016-09-14 13:06 GMT+02:00 Martin Landa [<landa.martin@gmail.com>](mailto:landa.martin@gmail.com):
db.tables -p
real password - good idea to change it before post here :-)
Ma
Benoit André
Directeur - Gérant
BCG SPRL
B-5000 - Namur
BCG LOGO
I will work through that during the weekend.
An example is not that easy with a remote database ...
Stefan
On 14/09/16 13:52, Martin Landa wrote:
schema = (null)
Ma
Stefan Lüdtke
of Brandenburg
2016-09-14 17:43 GMT+02:00 Benoit ANDRE <benoit.andre@bcgeol.be>:
`--> db.login dri=pg datab=administration host=192.168.1.200 user=benoit
port=5432
btw, no password needed for connection?
Ma
Martin Landa
Hi there,
the suggestion below works. The other one suggested later on with "dri"
instead of "driver" by Martin with 7.0.5svn as well. I get a list of
tables with db.tables -p.
But non of them shows a list of vectors/rasters when I go for the "link"
or "import" within the gui. I can select a db from that server I am
connected to, but no table is shown.
Did the debug output from Benoit ANDRE helps anything? I guess mine
would still be interresting?
Stefan
On 14/09/16 13:06, Martin Landa wrote:
1)
host=vmhydro27
please try out:
Ma
Stefan Lüdtke
of Brandenburg
Hi Martin,
I tried again with last release (7.0.5RC2) announced by Markus, but without results. Problem 's staying the same : no connection. The arguments to call ‘psql’ seems missing.
(attachments)
Le 16/09/16 21:12, Stefan Lüdtke a écrit :
Hi there,
Stefan
2016-09-12 13:22 GMT+02:00 Stefan Lüdtke [<sluedtke@gfz-potsdam.de>](mailto:sluedtke@gfz-potsdam.de):
1)
host=vmhydro27
please try out:
Ma
Benoit André
Directeur - Gérant
BCG SPRL
B-5000 - Namur
BCG LOGO
I have not tried again in order to provide debug messages. Because I am
not sure whether they show anything new/different to the messages Benoit
ANDRE showed to us but its quite a bit of effort to compile from svn.
Is that output from my side still required??
Stefan
On 21/09/16 13:42, Benoit ANDRE wrote:
Hi Martin,
arguments to call 'psql' seems missing.
Hi there,
Stefan
1)
host=vmhydro27
please try out:
Ma
*Benoit André*
*Directeur - Gérant*
benoit.andre@bcgeol.be <mailto:benoit.andre@bcgeol.be>
<https://be.linkedin.com/in/benoitandre&gt;
*BCG SPRL*
B-5000 - Namur
www.bcgeol.be <http://www.bcgeol.be> - plan d'accès
<https://maps.google.be/maps/ms?msid=210366068780572446312.0004dc0b834462107c00f&msa=0&ll=50.460427,4.856445&spn=0.001279,0.002411&iwloc=0004dc0b8345e35a35a20&gt;
  BCG LOGO <http://www.bcgeol.be>
<https://www.linkedin.com/company/bureau-conseil-en-géologie-sprl&gt; Lien
Facebook
<https://www.facebook.com/Bureau-Conseil-en-Géologie-153924548320189/?ref=hl&gt;
Allons plus loin dans le respect de l'environnement : N'utilisons que
<https://www.modere.eu/?referralCode=050281&gt;
Stefan Lüdtke
of Brandenburg
On Sep 21, 2016 1:50 PM, “Stefan Lüdtke” <sluedtke@gfz-potsdam.de> wrote:
On Linux that’s not more than
svn update
make
Since most was compiled before, it will take something like 60sec…
Finally perhaps (not me, I just run GRASS GIS directly from the compiled source code directory):
make install
Does it work for you?
I'll give it a go ... that sounds doable :wink:
On 21/09/16 14:00, Markus Neteler wrote:
On Sep 21, 2016 1:50 PM, "Stefan Lüdtke" <sluedtke@gfz-potsdam.de
<mailto:sluedtke@gfz-potsdam.de>> wrote:
On Linux that's not more than
svn update
make
Since most was compiled before, it will take something like 60sec...
make install
Stefan Lüdtke
of Brandenburg
Hi Moritz,
I tried with last release (7.0.5RC2) on my server (where postgresql is running) and not on a remote workstation. Connection to database is then a local connection. Here, there is no problem to work with postgresql. The problem seems thus to be linked with a remote acces…
Benoit
(attachments)
functionality.
Moritz
Benoit ANDRE [<benoit.andre@bcgeol.be>](mailto:benoit.andre@bcgeol.be) a écrit :
Hi list,
and 7.0.3
Hi list,
on the web by know.
success.
What I have done:
1)
3) db.tables -p
Connection failed.
Connection failed.
success.
visualize the data.
Package: grass
Priority: optional
Installed-Size: 33
[<pkg-grass-devel@lists.alioth.debian.org>](mailto:pkg-grass-devel@lists.alioth.debian.org) Architecture: all
Suggests: grass-dev
connection string.
Stefan
Benoit André
Directeur - Gérant
BCG SPRL
B-5000 - Namur
BCG LOGO
Hi Benoît and Stefan,
On 26/09/16 14:20, Benoit ANDRE wrote:
Hi Moritz,
postgresql. The problem seems thus to be linked with a remote acces...
I think I have found the origin of the problem. Please see the discussion in the relevant bug report [1].
Both of you say that you did set usernam and password in db.login. Could you check the contents of .grass7/dblogin ? Are there empty fields before the host entry ?
Moritz
[1] https://trac.osgeo.org/grass/ticket/3167
Benoit
functionality.
Moritz
Hi list,
and 7.0.3
Hi list,
on the web by know.
success.
What I have done:
1)
3) db.tables -p
Connection failed.
Connection failed.
success.
visualize the data.
Package: grass
Priority: optional
Installed-Size: 33
Suggests: grass-dev
connection string.
Stefan
*Benoit André*
*BCG SPRL*
B-5000 - Namur
Facebook
if I do not set all parameters with db.login I do have empty fields in
that file, even though I put that parameters in the db.connect command.
If everything is in db.login, I can connect to the db (as reported
earlier) and list tables. However I can neither link nor import them
because they are not listed in the gui box.
Stefan
Hi Moritz,
Moritz
Benoit
functionality.
Moritz
Hi list,
and 7.0.3
Hi list,
on the web by know.
success.
What I have done:
1)
3) db.tables -p
Connection failed.
Connection failed.
success.
visualize the data.
Package: grass
Priority: optional
Installed-Size: 33
Suggests: grass-dev
connection string.
Stefan
*Benoit André*
*BCG SPRL*
B-5000 - Namur
Facebook
Stefan Lüdtke
of Brandenburg
Hi Moritz,
It works fine with your suggestion… Thank you.
First : I erase ./grass7/dblogin (outside grass)
2nd : I go into grass 7.0.4
3th :
  • db.connect driver=pg database=administration
  • db.login driver=pg database=administration user=benoit password=rien host=192.168.1.200 port=5432
No matter if a password is necessary in my case
Then, I had to reconnect map to table with
4th : v.db.connect -o map=survey_bcg@benoit driver=pg database=administration table=public.survey_bcg
The only place where host and port arise is in the ‘db.login’ function.
OK. Now, I’m able to make the jump to grass 7.
Thank you again, Moritz.
Ben.
(attachments)
Le 27/09/16 14:52, Stefan Lüdtke a écrit :
Stefan
Hi Moritz,
Moritz
[1] [https://trac.osgeo.org/grass/ticket/3167](https://trac.osgeo.org/grass/ticket/3167)
Benoit
functionality.
Moritz
Hi list,
and 7.0.3
Hi list,
on the web by know.
success.
What I have done:
1)
3) db.tables -p
Connection failed.
Connection failed.
success.
visualize the data.
Package: grass
Priority: optional
Installed-Size: 33
Suggests: grass-dev
connection string.
Stefan
*Benoit André*
[benoit.andre@bcgeol.be](mailto:benoit.andre@bcgeol.be) [<mailto:benoit.andre@bcgeol.be>](mailto:benoit.andre@bcgeol.be)
[<https://be.linkedin.com/in/benoitandre>](https://be.linkedin.com/in/benoitandre)
*BCG SPRL*
B-5000 - Namur
[www.bcgeol.be](http://www.bcgeol.be) [<http://www.bcgeol.be>](http://www.bcgeol.be)  -  plan d'accès
[<https://maps.google.be/maps/ms?msid=210366068780572446312.0004dc0b834462107c00f&msa=0&ll=50.460427,4.856445&spn=0.001279,0.002411&iwloc=0004dc0b8345e35a35a20>](https://maps.google.be/maps/ms?msid=210366068780572446312.0004dc0b834462107c00f&msa=0&ll=50.460427,4.856445&spn=0.001279,0.002411&iwloc=0004dc0b8345e35a35a20)
    BCG LOGO [<http://www.bcgeol.be>](http://www.bcgeol.be)
[<https://www.linkedin.com/company/bureau-conseil-en-g%C3%A9ologie-sprl>](https://www.linkedin.com/company/bureau-conseil-en-g%C3%A9ologie-sprl) Lien
Facebook
[<https://www.facebook.com/Bureau-Conseil-en-G%C3%A9ologie-153924548320189/?ref=hl>](https://www.facebook.com/Bureau-Conseil-en-G%C3%A9ologie-153924548320189/?ref=hl)
[<https://www.modere.eu/?referralCode=050281>](https://www.modere.eu/?referralCode=050281)
Benoit André
Directeur - Gérant
BCG SPRL
B-5000 - Namur
BCG LOGO
