Hi, I am having trouble changing my PS1 bash prompt in Grass 7.7svn. I have PS1 set to “\W >” in ~/.grass.bashrc, but instead my prompt consistently prints
“GRASS 7.7.svn ($LOCATION_NAME):\w > “ (with LOCATION_NAME and \W expanded to current Grass location and full directory path, respectively). The result is my prompt is eating almost the full width of my shell window.
Just wondering what other resource files need to be changed?
On Thu, Feb 28, 2019 at 3:20 PM Patton, Eric (NRCan/RNCan)
Just to be sure: what is $SHELL set to? What is the output of:
On my system (Debian, GRASS 7.6) it’s ~/.grass7/bashrc
~ Eric.
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
On Thu, Feb 28, 2019 at 3:20 PM Patton, Eric (NRCan/RNCan) <eric.patton@canada.ca> wrote:
have
consistently prints
echo $SHELL
and
ls -la $(which $SHELL)
Markus,
Here is the output:
echo $SHELL
/bin/bash
ls -al $(which $SHELL)
-rwxr-xr-x 1 root root 1037440 May 26 2017 /bin/bash
On Thu, Feb 28, 2019 at 3:21 PM Patton, Eric (NRCan/RNCan) <eric.patton@canada.ca> wrote:
You could directly hack the GRASS startup script grass77, there in the fn bash_startup() the line that defines PS1, around L1772.
Micha, I don’t have a bashrc file in ~.grass7. And copying ~/.grass.bashrc to ~/.grass7/bashrc and restarting Grass doesn’t change anything (PS1 remains the same). It seems the grass77 startup is clobbering all other places where $PS1 is set.
