I'm trying to reproduce an exercise of the GRASS book, third edition, pp. 145-146, which demonstrates the usage of r.water.outlet. Using exactly the same commands as listed in the book, I get a basin which is hardly visible unless zooming very closely to it. r.report reports a size of 0.0002 ha. Is this normal ?
The relevant commands in the book are (for the NC dataset):
this normal ?
The version of r.watershed used for the example in the book had some
bugs, in particular a bias towards diagonal drainage direction which
is mosz notable with high-res LiDAR DEMs like elev_lid792_1m. One
consequence is that accumulation patterns shifted a bit and
east=638872.6 north=220042.6 are most probably no longer falling onto
a main channel leading to minute basins. Try plotting east=638872.6
north=220042.6 on top of accum_5K and adjusting the coords such that
they fall onto the nearest main channel.
On Wed, Sep 7, 2011 at 8:22 AM, Markus Metz
<markus.metz.giswork@googlemail.com> wrote:
Moritz Lennert wrote:
Hello,
145-146, which demonstrates the usage of r.water.outlet. ...
I have added NULL support in r.water.outlet and added a working example to
the manual page [1]. Works nicely.
Hello,
