[GRASS-user] unable to start grass 7
Nataniel wrote:
Hi,Grass7 works fine. I saw finally an error message on a popup
window "cannot import name MAXREPEAT" where the issue is to
update the python version to 2.7.5
grass7 has a file called %GISBASE%\etc\env.bat, which contains
  set GRASS_PYTHON=%GISBASE%\extrabin\python.exe
so GRASS's version of python is always used.
grass6.x just has:
  set GRASS_PYTHON=python
so the first python.exe found on the system is used.
see https://trac.osgeo.org/grass/ticket/1981#comment:2
since this is regularly coming up, if there are no objections
I will backport that to 6.x ASAP.
thanks for the feedback,
Hamish
