I am running v.in.ogr to import a PostGIS table. This table shows up fine in QGIS. Here’s the command:
v.in.ogr -o “dsn=PG:dbname=‘de’ host=localhost port=5432 user=‘[redacted]’ password=‘[redacted]’ sslmode=disable” layer=consistent.master output=master_grassX
This command was produced by QGIS’s GRASS Tools.
The problem is that I get an error but no explanation at all. Here’s the output:
Width for column school_zone set to 255 (was not specified by OGR), some strings may be truncated!
Width for column vehicle_color set to 255 (was not specified by OGR), some strings may be truncated!
Width for column offense_location set to 255 (was not specified by OGR), some strings may be truncated!
Width for column work_zone set to 255 (was not specified by OGR), some strings may be truncated!
DBMI-DBF driver error:
Unable to create table: ‘create table master_grassX (cat integer, offense_street_name varchar ( 30 ), school_zone varchar ( 255 ), defendant_dl varchar ( 20 ), defendant_dl_state varchar ( 2 ), vehicle_model varchar ( 20 ), offense_code integer, vehicle_color varchar ( 255 ), citation_id_base varchar ( 20 ), vehicle_make varchar ( 20 ), defendant_dob date, speed_limit integer, source varchar ( 20 ), vehicle_registration_expiration_date date, offense_crossstreet_number varchar ( 10 ), defendant_sex varchar ( 1 ), citing_jurisdiction integer, offense_county varchar ( 10 ), officer_id varchar ( 20 ), offense_location varchar ( 255 ), defendant_zip varchar ( 9 ), vehicle_licenseplate_state varchar ( 2 ), offense_street_number varchar ( 10 ), offense_timestamp datetime, citation_id_stub varchar ( 20 ), offense_crossstreet_name varchar ( 30 ), speed_alleged integer, vehicle_year integer, vehicle_licenseplate varchar ( 10 ), work_zone varchar ( 255 ), defendant_race varchar ( 10 ))’
Finished with error
The problem is I get no details at all on the error cause. Yes, the driver error really is blank.
I turned postgres logging to log all queries (following the recipe at http://stackoverflow.com/questions/722221/how-to-log-postgres-sql-queries). I analyzed the queries and didn’t see anything surprising. I’ve attached the log in case it’s helpful.
I checked the /dbf directory, and it has no files. I also checked the vector/master_grassX directory and found no problems, just four files (coor, dbln, head, hist) with unsurprising contents.
I’m new to GRASS, so I’m not sure what else to check. Is there another log source? Did I discover a bug that needs to be filed?
Aren Cambre
(attachments)
postgres.log (6.76 KB)
