[GRASS-user] units for dmax,dmin in v.distance
Quick question:
Does anyone know what the units are when using dmax and dmin options in v.distance? I have a lat/lon map ... map units are degrees.
The man page says it OUTPUTS in meters for lat/lon maps, but does it use meters for INPUTS or degrees for lat/lon maps? The man page doesn't say...
Thanks!
:slight_smile:
Chris
Chris Bartolomei P.E.
Engineer/Scientist
ENSCO, Inc.
bartolomei.chris@ensco.com
The information contained in this email message is intended only for the use of the individual(s) to whom it is addressed and may contain information that is privileged and sensitive. If you are not the intended recipient, or otherwise have received this communication in error, please notify the sender immediately by email at the above referenced address and note that any further dissemination, distribution or copying of this communication is strictly prohibited.
The U.S. Export Control Laws regulate the export and re-export of technology originating in the United States. This includes the electronic transmission of information and software to foreign countries and to certain foreign nationals. Recipient agrees to abide by these laws and their regulations -- including the U.S. Department of Commerce Export Administration Regulations and the U.S. Department of State International Traffic in Arms Regulations -- and not to transfer, by electronic transmission or otherwise, any content derived from this email to either a foreign national or a foreign destination in violation of such laws.
On 13/05/16 07:04, Bartolomei.Chris wrote:
Quick question: Does anyone know what the units are when using dmax
are degrees. The man page says it OUTPUTS in meters for lat/lon maps,
Just did a little test in a lat-long location: it's meters. For two points, about 1 degree apart, you need a dmax of about 100,000...
Moritz
On Fri, May 13, 2016 at 9:53 AM, Moritz Lennert
Yes, the code contains the cal to geodesic functions.
I have added a note in the manual page (r68426 trunk and r684267 relbranch70).
