[GRASS-user] Unix and Grass commands in Windows
Stephen wrote:
Hi Folks Just wondering how best to execute Unix and Grass
commands using Grass 6/7.0. I’m running Windows Vista,
for GRASS 6.4 it is this one:
Start -> Programs -> GRASS GIS 6.4.3 -> GRASS GIS 6.4.3 with MSYS.
and had
started installing Cygwin, but this seems to be massive, and
not even sure if this is the best environment, as some users
don’t seem happy about it.
It's ok, just overkill for what you want to do. People will
always be unhappy with something or other on the internet, I
wouldn't let that stop you. :slight_smile: Yes, the installer is a pain.
I had initially thought I could use the Console window, but
this appears not to accept Unix commands.
type "bash" at that prompt and it will. (maybe follow by
" PS1='GRASS:\W> ' " to get the prompt look back)
I'm concerned that the CMD.EXE dos box console in 6.4 is still a
bit half baked. The "rxvt" which runs the MSYS is not ideal
either, but at least it generally works and occasionally doesn't,
as opposed to the current CMD.EXE (GRASS Command Line + running
g.gui) in 6.x, which seems to me lately to be lots of things
not working. I don't use this day to day, so take with a
grain of salt, maybe mine had a bad day when I tried it.
I also tried the included MySys Unix console which appears to
be a Bash shell, but this does not recognise Grass commands.
there are two menu items:
- GRASS GIS 6.4.3 with MSYS
- MSYS UNIX Console
the second one is just a generic UNIX prompt, the GRASS
environment has not been loaded for you. the first one is
what you want.
What would you recommend is the best option if I want to use
Grass quite a lot, but don’t want to convert my PC to a fully
fledged Linux system (unless that really is the best option,
such as using an emulator).
I'd try the GRASS+MSys first. If that has problems, then it's
pretty easy to install the free VirtualBox Virtual Machine
software, then load something like xUbuntu of the OSGeo Live
demo onto it. There are some step by step instructions on how
to do that here:
  http://live.osgeo.org
What I like about the Virtual Machines is that it makes the
whole OS choice debate a bit moot. Set whichever one you're
running to full screen, and there you are.
GRASS is still smoother on UNIX (Linux/Mac/...), but we're trying
to level the playing field as fast as we can. There are still a
few rough edges on Windows, but it's getting much closer.
good luck,
Hamish
Hamish
Thanks for your excellent response.
Confirmed a few of my suspicions, plus some honest comment/nudges to others.
-Appreciate the hard work everybody is putting in!
  Stephen
-----Original Message-----
Sent: 22 April 2013 12:27
To: grass-user@lists.osgeo.org; Stephen Brearley
Subject: Re: [GRASS-user] Unix and Grass commands in Windows
Stephen wrote:
Hi Folks Just wondering how best to execute Unix and Grass commands
and had
started installing Cygwin, but this seems to be massive, and not even
sure if this is the best environment, as some users don’t seem happy
about it.
It's ok, just overkill for what you want to do. People will always be unhappy with something or other on the internet, I wouldn't let that stop you. :slight_smile: Yes, the installer is a pain.
I had initially thought I could use the Console window, but this
type "bash" at that prompt and it will. (maybe follow by " PS1='GRASS:\W> ' " to get the prompt look back)
I'm concerned that the CMD.EXE dos box console in 6.4 is still a bit half baked. The "rxvt" which runs the MSYS is not ideal either, but at least it generally works and occasionally doesn't, as opposed to the current CMD.EXE (GRASS Command Line + running
g.gui) in 6.x, which seems to me lately to be lots of things not working. I don't use this day to day, so take with a grain of salt, maybe mine had a bad day when I tried it.
I also tried the included MySys Unix console which appears to be a
- MSYS UNIX Console
the second one is just a generic UNIX prompt, the GRASS environment has not been loaded for you. the first one is what you want.
What would you recommend is the best option if I want to use Grass
quite a lot, but don’t want to convert my PC to a fully fledged Linux
system (unless that really is the best option, such as using an
emulator).
I'd try the GRASS+MSys first. If that has problems, then it's pretty easy to install the free VirtualBox Virtual Machine software, then load something like xUbuntu of the OSGeo Live demo onto it. There are some step by step instructions on how to do that here:
What I like about the Virtual Machines is that it makes the whole OS choice debate a bit moot. Set whichever one you're running to full screen, and there you are.
GRASS is still smoother on UNIX (Linux/Mac/...), but we're trying to level the playing field as fast as we can. There are still a few rough edges on Windows, but it's getting much closer.
good luck,
Hamish
