[GRASS-user] unsuccesful installing r.univar2.zonal with g.extension
I just tried installing r.univar2.zonal using g.extension. i am using Grass6.5svn
I got an error at the end “Module did not install properly”
As a test I also tried (successfully)
GRASS 6.5.svn (cru):~/himalaya > g.extension extension=v.rast.stats2
Here is what happened with r.univar2.zonal: any ideas?
GRASS 6.5.svn (cru):~/himalaya > g.extension extension=r.univar2.zonal
Fetching <r.univar2.zonal> from GRASS-Addons SVN (be patient)…
A r.univar2.zonal/stats.c
A r.univar2.zonal/sort.c
A r.univar2.zonal/globals.h
A r.univar2.zonal/r.univar.zonal.html
A r.univar2.zonal/r.univar_main.c
A r.univar2.zonal/r3.univar.zonal.html
A r.univar2.zonal/r3.univar_main.c
A r.univar2.zonal/Makefile
U r.univar2.zonal
Checked out revision 43600.
Compiling <r.univar2.zonal>…
test -d OBJ.i686-pc-linux-gnu || mkdir -p OBJ.i686-pc-linux-gnu
gcc -I/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/include -g -O2 -DPACKAGE="“grassmods”" -I/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/r.univar_main.o -c r.univar_main.c
gcc -I/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/include -g -O2 -DPACKAGE="“grassmods”" -I/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/sort.o -c sort.c
gcc -I/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/include -g -O2 -DPACKAGE="“grassmods”" -I/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/stats.o -c stats.c
gcc -L/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/lib -Wl,–export-dynamic -Wl,-rpath-link,/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/lib -L/usr/local/pgsql/lib/ -o /home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin/r.univar.zonal OBJ.i686-pc-linux-gnu/r.univar_main.o OBJ.i686-pc-linux-gnu/sort.o OBJ.i686-pc-linux-gnu/stats.o -lgrass_g3d -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -lz -lz -lm
gcc -I/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/include -g -O2 -DPACKAGE="“grassmods”" -I/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/r3.univar_main.o -c r3.univar_main.c
gcc -L/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/lib -Wl,–export-dynamic -Wl,-rpath-link,/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/lib -L/usr/local/pgsql/lib/ -o /home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin/r3.univar.zonal OBJ.i686-pc-linux-gnu/r3.univar_main.o OBJ.i686-pc-linux-gnu/sort.o OBJ.i686-pc-linux-gnu/stats.o -lgrass_g3d -lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_dModule did not install properlyatetime -lz -lz -lm
make htmlmulti
make[1]: Entering directory /home/vishal/grassdata/cru/rad/.tmp/SEI-Davis/8982.0/r.univar2.zonal'* *for prog in r.univar.zonal r3.univar.zonal ; do make htmlcmd PGM=$prog ; done* *make[2]: Entering directory /home/vishal/grassdata/cru/rad/.tmp/SEI-Davis/8982.0/r.univar2.zonal’
make /home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/docs/html/r.univar.zonal.html HTMLSRC=/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin/r.univar.zonal
make[3]: Entering directory /home/vishal/grassdata/cru/rad/.tmp/SEI-Davis/8982.0/r.univar2.zonal'* *if [ "/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin/r.univar.zonal" != "" ] ; then GISRC=/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu PATH="/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin:/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/lib:/usr/local/grass-6.5.svn/lib" LC_ALL=C /home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin/r.univar.zonal --html-description < /dev/null | grep -v '</body>\|</html>' > r.univar.zonal.tmp.html ; true ; fi* <i>/usr/local/grass-6.5.svn/tools/mkhtml.sh r.univar.zonal ; mkdir -p /home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/install -c -m 644 r.univar.zonal.tmp.html /home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/docs/html/r.univar.zonal.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true</i> *make[3]: Leaving directory /home/vishal/grassdata/cru/rad/.tmp/SEI-Davis/8982.0/r.univar2.zonal’
make[2]: Leaving directory /home/vishal/grassdata/cru/rad/.tmp/SEI-Davis/8982.0/r.univar2.zonal'* *make[2]: Entering directory /home/vishal/grassdata/cru/rad/.tmp/SEI-Davis/8982.0/r.univar2.zonal’
make /home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/docs/html/r3.univar.zonal.html HTMLSRC=/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin/r3.univar.zonal
make[3]: Entering directory /home/vishal/grassdata/cru/rad/.tmp/SEI-Davis/8982.0/r.univar2.zonal'* *if [ "/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin/r3.univar.zonal" != "" ] ; then GISRC=/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/demolocation/.grassrc65 GISBASE=/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu PATH="/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin:$PATH" LD_LIBRARY_PATH="/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin:/home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/lib:/usr/local/grass-6.5.svn/lib" LC_ALL=C /home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/bin/r3.univar.zonal --html-description < /dev/null | grep -v '</body>\|</html>' > r3.univar.zonal.tmp.html ; true ; fi* <i>/usr/local/grass-6.5.svn/tools/mkhtml.sh r3.univar.zonal ; mkdir -p /home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/docs/html ; /usr/bin/install -c -m 644 r3.univar.zonal.tmp.html /home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/docs/html/r3.univar.zonal.html ; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ; if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file /home/vishal/src/grass6_dev/dist.i686-pc-linux-gnu/docs/html ; fi done 2> /dev/null ; true</i> *make[3]: Leaving directory /home/vishal/grassdata/cru/rad/.tmp/SEI-Davis/8982.0/r.univar2.zonal’
make[2]: Leaving directory /home/vishal/grassdata/cru/rad/.tmp/SEI-Davis/8982.0/r.univar2.zonal'* *make[1]: Leaving directory /home/vishal/grassdata/cru/rad/.tmp/SEI-Davis/8982.0/r.univar2.zonal’
Installing r.univar2.zonal…
*if [ “” != “” ] ; then *
*for dir in ; do *
*make -C $dir install ; *
*done ; *
fi
ERROR: Module did not install properly
Vishal
Vishal K. Mehta, PhD
Scientist
Stockholm Environment Institute - US
133 D St Suite F
Davis CA 95616
www.sei-us.org
