Hi Ken,
In SQLite it would look like this:
SELECT substr(CAST(date('2015-01-01', +CAST(DOY -1 AS text) || ' days') AS text), 6, 2);
Or
SELECT CAST(ltrim(substr(CAST(date(CAST(2015 AS text) || '-01-01', +CAST(2-1 AS text) || ' days') AS text), 6, 2), '0')as smallint)
If you want numeric return.
Thus, try:
db.select sql="SELECT substr(CAST(date('2015-01-01', +CAST(134 -1 AS text) || ' days') AS text), 6, 2);"
To see how it works...
Then try something like:
v.db.update map=CTD_2015 column=YMD value= substr(CAST(date('2015-01-01', +CAST(DOY -1 AS text) || ' days') AS text), 6, 2)
or
db.select sql="UPDATE CTD_2015 SET YMD = substr(CAST(date('2015-01-01', +CAST(134 -1 AS text) || ' days') AS text), 6, 2);"
Stefan
-----Original Message-----
From: grass-user [mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of Ken Mankoff
Sent: torsdag 12. januar 2017 17.49
To: Helmut Kudrnovsky <hellik@web.de>
Cc: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] update column w/ output from bash function
Hi Helmut,
I misspoke and the data column I'm working with is not Julian Day (JD) but Day of Year (DOY). I looked at the SQL datetime functions and can't find a way to convert DOY to YYY-MM-DD. Can you help with this?
Also, you are correct, these modules do not work with bash. Is there any way to populate a column with something other than SQL? I think SQL is Turing complete and therefore can be used for arbitrarily complex functions, but it doesn't seem like the right tool in this case. There are simple bash commands that can generate the data, but I have no way to get that data into the column without a for loop, which is computationally slow. My current solution is:
# extract the category (unique) and the DOY column (1 and 13) for cat_DOY in $(db.select table=CTD_2015| cut -d"|" -f1,13); do
# separate into category and DOY
cat=$(echo $cat_DOY | cut -d"|" -f1)
DOY=$(echo $cat_DOY | cut -d"|" -f2)
YMD=$(doy2ymd 2015 ${DOY})
v.db.update map=CTD_2015 column=YMD where="cat = ${cat}" value=${YMD} done
-k.
On 2017-01-12 at 14:56, Helmut Kudrnovsky <hellik@web.de> wrote:
Helmut Kudrnovsky wrote
Neither db.execute nor db.select appear to work with arbitrary bash
commands.
AFAIK these modules need a SQL statement, not a bash command; e.g. [1]:
db.execute - Executes any SQL statement.
[1] https://grass.osgeo.org/grass73/manuals/db.execute.html
there are some sqlite Date And Time Functions:
https://www.sqlite.org/lang_datefunc.html
best regards
Helmut
grass-user mailing list
