[GRASS-user] updated ordinary kriging example using spearfish
I have just posted an example of ordinary kriging using the common spearfish
data. This is based as close as possible to the most current use of GRASS-R
bindings. Any criticism is appreciated, as this example will be going into
other materials... and needs to be as up-to-date as possible.
again this is just an example, not a treatise on geostatistics.
http://casoilresource.lawr.ucdavis.edu/drupal/node/438
cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Dylan Beaudette a écrit :
I have just posted an example of ordinary kriging using the common spearfish data. This is based as close as possible to the most current use of GRASS-R bindings. Any criticism is appreciated, as this example will be going into other materials... and needs to be as up-to-date as possible.
cheers,
Perhaps I would say that to conducte a geostatistic interpolation a best as possible, it's missing an anysothropy analysis before choosing to fit a model to your semi-variogram. Looking to your primary results, it seems that there is variance gradient North-South, so that perhaps the variogram have to be construct to take it into account if exists.
Regards
Emmanuel Poizot
Cnam/Intechmer
B.P. 324
50103 Cherbourg Cedex
Phone (Direct) : (00 33)(0)233887342
Fax : (00 33)(0)233887339
> Hi,
> possible.
> cheers,
Regards
Emmanuel Poizot
Cnam/Intechmer
B.P. 324
Thanks for the comments Emmanuel. I agree that there should always be an
investigation into all of the factors which might otherwise invalidate the
intrinsic hypothesis of kriging [1].
I have included a couple extra code snippets and figure into the main material
that I am working on. I will integrate this into the original article, until
then - here is a related page:
http://casoilresource.lawr.ucdavis.edu/drupal/node/442
PS: your feelings about the anisotropy matched mine as well, along with the
attached variogram map
1. Issaks, E.H. & Srivastava, R.M. An Introduction to Applied Geostatistics
Oxford University Press, 1989
Dylan Beaudette
530.754.7341
(attachments)
variogram_map.pdf (11 KB)
