[GRASS-user] Updating Raster Categories without using r.support?
Hi all
I still haven't finally sorted out my Ubuntu install. Will report on
it when it comes right!
I am back on Windows, working via QGIS and the MSys Grass shell. I am
trying to set categories for a raster map (imported from a Geotiff of
a classified image). I have copied it out of the Permanent mapset to
be able to make edits, and used r.support:
"r.support inkomati_utm36wgs_upd
Edit header for [inkomati_utm36wgs_upd]? (y/n) [n] n
Update the statistics (histogram, range) for [inkomati_utm36wgs_upd]?
(y/n) [n] n
Edit the category file for [inkomati_utm36wgs_upd]? (y/n) [n] y
Redirection is not supported."
Is there a way to set the categories by editing a file directly?
Thanks!
Brendon
(y/n) [n] n
You can use "r.category ... rules=..." to set category labels
non-interactively.
