I have a municipality polygon layer with a poverty index (percent) and a population count, I’m multiplying them to visualize the vulnerability for each municipality, due to the distribution of that new variable I want to compute the logarithm, which is not possible in sqlite, so I tried reading the column with numpy and issuing a np.log10(). I’m happy with the result, but how can I get this new numpy array to a new column in the vector map in a simple way?
This is what I already have:
#!/usr/bin/env python
import grass.script as gs
import numpy as np
import matplotlib.pyplot as plt
I’m trying to introduce this kind of analysis to students who are not familiar nor proficient with programming (this is an GIS introductory course) so the numpy bit is already complex enough to them, and I’d like to avoid using for loops with cursors to achieve this.
On Thu, Feb 14, 2019 at 12:50 PM César Augusto Ramírez Franco <caesarivs@gmail.com> wrote:
Greetings,
import numpy as np
On 2/14/19 4:49 PM, César Augusto Ramírez Franco wrote:
Greetings,
import numpy as np
I also can’t think of any simple way to do this. However PostgreSQL does have a log() function. So if you migrate your backend DB to PostgreSQL you should be able to do (not tested):
But I must say that it seems strange that you are introducing numpy, matplotlib and the GRASS python interface to students who don’t yet have the basic tools of programming, such as ‘for’ loops. Isn’t this is a case of “putting the wagon in front of the horse”??
Is there a simple solution to this?
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Am Do., 14. Feb. 2019, 15:50 hat César Augusto Ramírez Franco <caesarivs@gmail.com> geschrieben:
Greetings,
import numpy as np
Greetings,
import numpy as np
That script hasn’t been introduced to students, I was just fiddling with the data after a class when the question arose, trying to figure out how to do that. I do most of the Lab research analysis with R, and lately I’ve been studying the scipy ecosystem to try and do them within R, but maybe Markus’ suggestion would do to get students going with their course’s projects.
Thanks!
On Fri, Feb 15, 2019, 09:17 Markus Neteler <neteler@osgeo.org wrote:
Greetings,
That’s actually pretty neat! I’ll test this in the lab’s computers this week.
import numpy as np
Thanks for the suggestion, this seems still kind of complex to do without proper programming knowledge, I’ll try Markus’ suggestion on monday, it seems like a much nicer approach than trying to explain numpy in the python console to students.
Greetings,
import numpy as np
