during grass session my inet connection failed and now it is impossible to start grass
[albert@ce ~]$ /localuser/soft/grass7_inst/bin/grass70 -text /home/albert/grassdata/bol/PERMANENT/
Cleaning up temporary files...
Starting GRASS GIS...
albert is currently running GRASS in selected mapset (file /home/albert/grassdata/bol/PERMANENT/.gislock found). Concurrent use not allowed.
[albert@ce ~]$
You could try to start GRASS with the GUI. Then you'll see
that your mapset you want to start is greyed out. Anyway
if you select it and click start GRASS will ask you if you
want to remove the GISLOCK.
Unfortunately I don't know how to remove the GIS lock
from the Terminal (but there must be a way other GIS users
know)
/j
On Fri, Oct 26, 2012 at 11:29 AM, Albert Saribekyan
<albertsaribekyan@rambler.ru> wrote:
Albert Saribekyan.
start grass
allowed.
[albert@ce ~]$
Cleaning up temporary files…
Starting GRASS GIS…
[albert@ce ~]$
2012/10/26 Albert Saribekyan <albertsaribekyan@rambler.ru>:
allowed.
[albert@ce ~]$
it indicates that another user uses this mapset or you just didn't
quit GRASS correctly. To access this mapset again, simply remove the
lock file.
rm /home/albert/grassdata/bol/PERMANENT/.gislock
I am waiting for Your answer!!
"waiting" is a nice word Please next time think about more
reasonable subject.
