[GRASS-user] Usage of R.Sun
Hi Paul,
Please don’t send me questions directly - as much as I like to help you out, I think that the list is a lot more reliable and when I can I answer there as well. I’ve CC’d this to the user list, in case other people have some ideas too. Answers are inline.
2012/12/27 Paul Meems <bontepaarden@gmail.com>
Hi Daniel,
I’ve finally got some time to look into GRASS.
I’ve downloaded GRASS GIS 6.4.3RC2.
I’ve found the sun radiation plug-in (r.sun). A lot of settings can be set :wink: I’ll look into it and perhaps ask you some questions later.
My first question is how to load my data?
My 0.5m DEM is a directory of 39 folders with ARCGIS Binary Grids (sta.adf). Should I first merge them into 1 large GeoTiff?
The size of my area is about 32 km2.
I’ve tried opening the adf files in Grass, but I’m not sure how to do that. Dropping the file didn’t work. Using ‘Import raster data’ seems to work.
Is that the correct one?
Yes, that’s correct. In GRASS, it’s best practice to always import data before you work with it. This has a lot of advantages which I won’t get into here, but the main one in my view is that you never have to worry about the data’s format again.
If you want, merge the rasters using some other tool into a GeoTIFF. If I’m not mistaken, GeoTIFF has a restriction on file size, meaning that rasters cannot be larger than 4 GB. Depending on the resolution of your rasters, this could be a problem. GRASS has no problem importing GeoTIFFs, and the size of the rasters is determined by the number of cells and their value ranges, not by the size of the area itself.
Here’s a good set of instructions on importing *.adf files into GRASS:
http://pvanb.wordpress.com/2010/03/15/esri-rasters-in-grass-or-qgis/
As mentioned by you before Grass calculates the solar radiation on a daily bases. I assume I can create a batch file to calculate the solar radiation for the whole year, but then I end up with 365 new files. I assume I need to add all values to 1 new raster. Which plug-in should I use for this?
You’re looking at a classic raster calculator operation. That can be done with r.mapcalc. It’s got a great manual that covers all of the options you might be interested in :slight_smile:
I hope you can help me. Grass has a steep learning curve and without some help it will be hard for me.
Just keep with it, GRASS does have a steep learning curve but it’s a very logical GIS and I’ve never regretted the time I spent getting to know it. Just don’t be afraid to read the manuals, use Google and ask questions and you’ll be fine :slight_smile: Looks like you’re right on track.
Cheers and happy New Years,
Daniel
