[GRASS-user] use r.sun with monthly cloud cover data
Dear GRASS users,
I would like to use the r.sun module to produce a map of montly solar
radiation for a certain area. I would like to incorporate cloud cover
data into the calculations, as well as information on local topography
(i.e. aspect and slope). I was wondering whether you could help me to
solve two problems: i) I have not quite yet understood what I should
do to specify a raster containing data on cloudiness when using the
module
eg. r.sun elevin=altmap aspin=aspmap slopein=slopemap + cloudmap?? ii)
I am interested in a montly average of daily sum of solar radiation,
and I only have montly cloud cover data. I suspect that this is not
ideal when calculations by r.sun are done on daily basis. Do you
confirm? Is there a way around this?
thanks in advance,
Simone
of montly solar
cloud cover
topography
slope and aspect are automatically taken into
account even if you don't use the slope and aspect
input map options.
actually due to a bug you shouldn't use them:
https://trac.osgeo.org/grass/ticket/498#comment:8
"r.sun2 commissioning trials"
just use the -s shading flag and the rest will
happen automatically.
help me to
I should
using the module
cloudmap??
from the help page:
Besides clear-sky radiations, the user can compute a real-sky
radiation (beam, diffuse) using coefbh and coefdh input
raster maps defining the fraction of the respective clear-sky
radiations reduced by atmospheric factors (e.g. cloudiness).
The value is between 0-1. Usually these coefficients can be
obtained from a long-terms meteorological measurements pro-
vided as raster maps with spatial distribution of these coef-
ficients separately for beam and diffuse radiation (see Suri
and Hofierka, 2004, section 3.2).
I've now updated the module in trunk and devbr6 to
(a little) better explain that.
ii)
radiation,
that this is not
Do you confirm? Is there a way around this?
If it's all you have to work with, it's all you have
to work with & you'll have to pretend like every
day is like the climactic average.
some LiCOR light data or even battery voltage from an installed
solar panel at a weather station can give you an
idea about which days are cloudy, and by how much.
Hamish
On Wednesday, January 18, 2012, Hamish wrote:
> of montly solar
> cloud cover
> topography
input map options.
Is this still the case? I get very odd results when I do not specify a slope
and aspect map.
https://trac.osgeo.org/grass/ticket/498#comment:18
Dylan
> help me to
> I should
> using the module
> cloudmap??
from the help page:
> ii)
> radiation,
> that this is not
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
Dylan E. Beaudette
USDA-NRCS Soil Scientist
California Soil Resource Lab
http://casoilresource.lawr.ucdavis.edu/
