[GRASS-user] use rgbcolumn for vector line in vareas ps.map
maning wrote:
I have an vector polygon where an attribute column defines the rgb
color for ps.map. The problem is, vareas options does not allow to
use the rgbcolumn for line color. Setting the width to very small
doesn't help either. Is there a way to disable line render in vareas.
to turn off boundaries set "color none"
rgbcolumn also works for pattern color by the way.
you can use a second vlines command with "type boundary" to draw
boundary lines, but typically those will not have category numbers
(and thus no GRASSRGB entry) because it is ambiguous as to which area
the boundary belongs to, i.e. take the color from the left or right
side of the line?
for vpoints see also http://trac.osgeo.org/grass/ticket/342
Or should I split the vector polys into separate layer of polygon
categories (too many).
  where cat IS >= x AND cat IS <= y
? (or similar SQL query for repeated vareas calls)
Hamish
Hamish,
Thanks for pointing out the obvious
color none!
Follow-up Q, how do I exclude polygon holes in vareas?
I'm starting to really like ps.map for batch processing map sheets :slight_smile:
side of the line?
Hamish
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
