Richard wrote:
Being more a scripter than a programmer, I suspect
g.pnmcomp is beyond me ... I can't really see how to pass a
map to the module, and can't really find any examples to help.
#spearfish example:
r.shaded.relief map=elevation.dem shade=elev.shade
g.region rast=elev.shade
d.mon x0
d.resize # ...
d.erase
d.rast elev.shade
d.out.file -t output=background format=ppm
d.erase
d.rast -o fields
d.out.file -t output=overlay format=ppm
d.erase
d.vect roads
d.out.file -t output=foreground format=ppm
d.erase
d.legend -c fields thin=4
d.barscale at=62.5,94
d.out.file -t output=decorations format=ppm
g.pnmcomp input=background.ppm,overlay.ppm,foreground.ppm,decorations.ppm \
mask=background.pgm,overlay.pgm,foreground.pgm,decorations.pgm \
output=merged.ppm outmask=merged.pgm opacity=1,0.5,1,0.8 \
width=`d.info -d | cut -f2 -d' '` height=`d.info -d | cut -f3 -d' '`
#from netpbm tools, see also the man page for 'pnmcomp'
(GRASS's g.pnmcomp is rather poorly documented)
So here's what I would like (ideally) a script to do:
1. set a variable (eg state)
for i in NSW QLD VIC; do
g.region vect=$i
2. Load gis.m with a .grc file
gis.m dmrc=Mymaps.grc
use d.* instead,
3. Pass $i to the "where" variable in a vector.
4. Zoom to the region.
6. Quit gis.m for the next state.
Is it feasible?
technically you could set up a gis.m .grc file from a script,
it's just a text file.. but I think you can do all you want
with a script like the above, or just with 'd.shadedmap' +
d.out.file if the only transparency you want is between 2 raster
maps. (but it sounds like you want it for vectors..)
Hamish
