[GRASS-user] Using a polygon as a Mask
Greetings
I have polygon that I want to use to define an for which I want to calculate some indicators (almost as a mask). Is it possible to use it directly in mapcalculator or do I have to convert it to RASTER and only then I can use it in mapcalculator as a mask?
Thanks
Best regards,
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5149 (20100527) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
There is no way to use a vector geometry in mapcalculator (or mapcalc) directly, hence, you have to convert it to raster before.
Christian.
From: "António Rocha" <antonio.rocha@deimos.com.pt>
Sent: Thursday, May 27, 2010 2:08 PM
To: "GRASS user list" <grass-user@lists.osgeo.org>
Subject: [GRASS-user] Using a polygon as a Mask
Greetings
Thanks
Best regards,
Antonio
http://www.eset.com
grass-user mailing list
Thank you Christian
What I am affraid is that when I convert Vector to RASTER I will obtain a mask that is not exacly the polygon in the boundaries of the polygon. For instance, if a pixel is "cuttted" by the polygons boundaries is it considered part odf the polygon or not?
Thanks
Antonio
Christian.
Greetings
Thanks
Best regards,
Antonio
http://www.eset.com
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5150 (20100527) __________
http://www.eset.com
Antonio,
an idea: if you know the "real" scale of your vector map then you can decide
(calculate) what the resolution of your raster map(s) would be. Then define
your region with a higher resolution and expect to have a reliable conversion.
Hope this is is correct and not misleading, Nikos
