[GRASS-user] Using d.shadedmap with ps.map
   I am having difficulties getting nviz to produce quality maps (version
6.4svn). Using d.shadedmap and annotating with The GIMP produces a fine
product. Is there a way to incorporate the capabilities of d.shadedmap
within a ps.map script?
   The display command drapes a raster over a shaded relief raster while the
latter seems to only overlay vector maps on a single raster map.
   Despite reading the nviz tutorial and manual several times I still cannot
get the north arrow, legends, or other annotations to produce sufficiently
high quality output.
Rich
(version 6.4svn). Using d.shadedmap and annotating with The GIMP
produces a fine product.
nviz elev=dem color=landsat
d.shadedmap within a ps.map script?
see the ps.output addon program for one way.
otherwise with ps.map you have to compose with d.shademap, then use
'd.out.file format=geotiff' with desired rows,cols and then r.in.gdal
the composite image back in. then you can use it with ps.map.
while the latter seems to only overlay vector maps on a single raster
map.
d.shademap only runs with 2 rasters (but you can overlay other d.*
commands too).
ps.map limits you to a single raster map, or RGB 3-raster group.
nviz will let you load multiple rasters. in addition, most "Surface
Attributes" for each map can be another raster map.
(I've sort of lost track of which module(s) this question is about)
cannot get the north arrow, legends, or other annotations to
produce sufficiently high quality output.
you can't get them to work at all? or e.g. the Arrow falls on top of
the word "North" etc. they are generally functional, but are still
rather clunky to use.
Hamish
