Hey guys,
A colleague is having problems with an archaic Grass project in that
geotiffs created from rasters in this Location only display correctly in
ArcGIS in UTM Zone 20 despite g.proj -p saying that the Location is UTM Zone
19. All the projection info I can find on data in this Location says it's
UTM 19, but the data displays as UTM20. We're pretty sure that the ArcGIS
data used as a check against the Grass data is correct (let's assume so for
the sake of this argument). Is it ok to go ahead and make backups of
PROJ_INFO and PROJ_UNITS, delete the originals, and then run g.setproj to
make new info files? Are there any dangers to doing this? This is uncharted
waters for me.
~ Eric.
On Fri, 12 May 2006 13:46:26 -0300
"Patton, Eric" <epatton@nrcan.gc.ca> wrote:
Hey guys,
in ArcGIS in UTM Zone 20 despite g.proj -p saying that the Location
is UTM Zone 19.
What do the gdalinfo say about your geotiffs?
Location says it's UTM 19, but the data displays as UTM20. We're
pretty sure that the ArcGIS data used as a check against the Grass
data is correct (let's assume so for the sake of this argument). Is
it ok to go ahead and make backups of PROJ_INFO and PROJ_UNITS,
delete the originals, and then run g.setproj to make new info files?
Are there any dangers to doing this? This is uncharted waters for me.
You could use gdal_translate -a_srs to correct the projection in the
output file.
Maciek
W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
