[GRASS-user] Using GIMPs Fuzzy Select tool on orthophotos (geotiff)
Apologies for cross-posting.
Can someone tell me why I should NOT use GIMPs "Fuzzy Select" tool to
select various "features" from an image (e.g. orthophoto), save
selection in a new file, add geo-metadata from the original image [1]
and continue my work in GRASS? It works so nice!
Could a tool like that implemented in GRASS to assist image
interpretation for example?
Thank you, Nikos
Nikos:
    Have you checked out any of the new minirasterstrip features in starspan yet? It takes vector data (any format that OGR supports), extracts a window (user defined size) around the vector out of a set of rasters (anything that GDAL supports), compiles it into a single image, and references the original vector data with the new compilation image.
    http://starspan.casil.ucdavis.edu
    Note: there is a small bug that will be fixed soon with the referenced vector -- once you get the minirasterstrip raster made, you'll need to re-define the raster projection to "arbitrary" with the original pixel size to get the associated vector lined up properly.
--j
P.S. Windows binaries (including an installer) and a java gui are now part of starspan! Enjoy!
Thank you, Nikos
grass-user mailing list
grass-user@lists.osgeo.org
Jonathan A. Greenberg, PhD
Postdoctoral Scholar
Center for Spatial Technologies and Remote Sensing (CSTARS)
University of California, Davis
One Shields Avenue
The Barn, Room 250N
Davis, CA 95616
Cell: 415-794-5043
AIM: jgrn307, MSN: jgrn307@hotmail.com, Gchat: jgrn307
