[GRASS-user] Using GRASS and PostGIS
Hello, all,
I've been proximal to GRASS for several years but never really used it much. I am currently working on macOS Catalina. One of the things that I find is that GRASS can get a bit slow here, part of which I attribute to running on SQLite/Spatialite.
I know that GRASS and PostGIS have different topology models, but is there some way to use it in lieu of SQLite as the primary datastore? I suspect that the power of PostgreSQL could make things a lot less painful for some of the bigger tasks.
If not PostGIS, what kind of tuneups can I do to help with this problem?
Dheeraj
On 22/10/19 21:41, Dheeraj Chand wrote:
Hello, all,
GRASS GIS supports PostgreSQL as database backend for attributes. You can set the default database backend in a mapset using db.connect [1]. Once this is set, any newly created vector map will use the defined backend. For existing maps see v.db.connect [2] and v.db.reconnect.all [3]. For general intro see [4].
If you want to store the actual geometries in PostGIS, you can use v.external [5] to link the data into a GRASS GIS mapset. You will not, however, profit of the full topological power you get when using the native GRASS GIS vector format.
Moritz
[1] https://grass.osgeo.org/grass78/manuals/db.connect.html
[2] https://grass.osgeo.org/grass78/manuals/v.db.connect.html
[3] https://grass.osgeo.org/grass78/manuals/v.db.reconnect.all.html
[4] https://grass.osgeo.org/grass78/manuals/databaseintro.html
[5] https://grass.osgeo.org/grass78/manuals/v.external.html
