[GRASS-user] Using GRASS on a ply file
‌Hello,
I have two point clouds of an open-pit mine taken a few weeks apart. I would like to estimate the volume that has been excavated during that interval, i.e the difference between the two point clouds. For that I used CloudCompare to get a new point cloud corresponding to the distance between the first two clouds. Now I need to know the
Z information of each point of this last cloud. I want to use GRASS to do it, but I can’t find a method that is working…
The first method I was suggested is to use v.in.ply and then r.report, but I have several issues:
  • When I use v.in.ply I have this error: ERROR: Wrong number of properties. Is it a common error? How can I solve it? I have attached a part of my .ply file to this email so you can see how it is formatted.
  • After importing my .ply file, I would like to use something like r.report to get the value of each point. However, I don’t know how to convert my file into a format that this command will work with… Could you help me?
The second method I read about is r.in.xyz, but I don’t know how it works, or what format of input I should use. Can I have more information about it?
Finally, it is the first time I am using GRASS, so I am not comfortable with all its functionalities. If you have the time, could you explain your answers step by step? It would be really kind.
Best,
Marion
(attachments)
BascFin2.ply (4.16 KB)
Hello Marion and welcome to the GRASS community !
On 06/06/18 12:03, marion-brunet wrote:
‌Hello,
Z information of each point of this last cloud. I want to use GRASS to do it, but I can't find a method that is working...
The first method I was suggested is to use*v.in.ply* and then*r.report*, but I have several issues:
- When I use *v.in.ply* I have this error: *ERROR: Wrong number of properties*. Is it a common error? How can I solve it? I have attached a part of my .ply file to this email so you can see how it is formatted.
[Marion sent me an extract of the data offline]
It seems that every data line in your .ply file has a trailing white space at the end. This is counted as an extra property and explains the message. When I erase these trailing white spaces, I don't get this error anymore. I don't know the format enough to know whether this is an issue with v.in.ply not tolerating these white spaces, or an issue with the program creating the .ply file which shouldn't add a white space at the end.
- After importing my .ply file, I would like to use something like *r.report *to get the value of each point. However, I don't know how to convert my file into a format that this command will work with... Could you help me?
r.report gives you a summary report about a raster, not a value by point.
Generally, if you want to cover an entire zone (your entire open-pit mine, you will probably want to go the raster way. So, with the points imported with v.in.ply, you could do something like the following:
g.region vect=points res=1 -ap #set the xy extension of your raster to the xy extension of the point cloud, and the resolution to 1 (you have to adjust that depending on the size of your zone)
v.surf.rst in=points out=mined_surface #interpolate a continous height surface across the entire area
r.volume mined_surface #calculate volume
The second method I read about is *r.in.xyz*, but I don't know how it works, or what format of input I should use. Can I have more information about it?
r.in.xyz is another option. It takes XYZ data and aggregates it by pixel using a user-determined aggregation function. If you have a higher point density than your target resolution, then you could use just the data part of your .ply file, i.e. the part which has lines such as
97.08156 121.6752 99.27532 0 0 0 12 9 2 255
97.08911 121.718 99.50104 0 0 0 46 40 24 255
93.25124 115.0372 102.7768 0 0 0 62 53 20 255
97.96031 123.8419 103.3994 0 0 0 150 184 211 255
97.10852 121.6866 99.42679 0 0 0 9 9 0 255
97.11196 121.7049 99.59032 0 0 0 19 12 4 255
97.13282 121.688 99.43796 0 0 0 38 28 16 255
97.17371 121.7129 99.41496 0 0 0 43 31 15 255
97.1614 121.6344 99.27691 0 0 0 9 6 1 255
Knowing that there are 17 lines of other info at the top of the extract you sent me, I could import the data using:
r.in.xyz in=BROL/BascFin2-extrait.ply skip=17 out=xyz_mean method=mean sep=space
However, as the extent of the cloud is very large, but there are only a few points, most of the pixels in the resulting raster are filled with NULL values as there are no points falling within these pixels.
Moritz
