[GRASS-user] using grass on rasters without converting?
Hello Grass World,
As a long time GIS user I've dipped into grass from time to time but never
in depth. One of the things that's deterred me is the fact that I have a
large body of data I work with (tens of gigabytes) and the prospect of
having to convert into grass, process it, and then flip it back out again is
unappealing. I respect the fact that the grass storage format allow it to do
things not possible otherwise. Is there any program available, or a project
in the works, for easy in-and-out conversion? or better yet, a method to use
grass commands on external formats like geotiff without conversion? Is this
a possibility in future or is the structure of grass such that it will just
never work? I'd love to be able to be able to do the likes of
"r.shaded.relief input=mydem.tif output=myshade.tif"
thanks,
-matt
View this message in context: http://www.nabble.com/using-grass-on-rasters-without-converting--tp20245591p20245591.html
Hi Matt,
On Thu, Oct 30, 2008 at 1:07 PM, matt wilkie <maphew@gmail.com> wrote:
Hello Grass World,
unappealing.
Sure - also for us :slight_smile: But it has been solved recently:
r.external - Link GDAL supported raster file to a binary raster map layer.
http://grass.osgeo.org/grass64/manuals/html64_user/r.external.html
Yes, you can do that from 6.4.svn onwards:
r.external [-r] in=/path/to/mydem.tif out=mydem
g.region rast=mydem -p
r.shaded.relief input=mydem shadedmap=myshade
r.out.gdal myshade out=myshade.tif
For r.out.gdal, check which format is appropriate to keep
the color table if desired.
Hope this helps,
Markus Neteler wrote:
Hi Matt,
Hello Grass World,
unappealing.
This solves a need for me too. Could something like that be done for WMS services, i.e. not downloading them with r.in.wms, but linking them without making a local copy?
Jan
unappealing.
Awesome! Thanks Markus (for letting me know) and everyone who worked
r.external. :slight_smile:
-matt
In theory, r.external might also accept WMS since GDAL does it:
http://www.gdal.org/frmt_wms.html
cat gdal_wms.xml
<GDAL_WMS>
    <Service name="WMS">
        <Version>1.1.1</Version>
        <ServerUrl>http://onearth.jpl.nasa.gov/wms.cgi?&lt;/ServerUrl&gt;
        <SRS>EPSG:4326</SRS>
        <ImageFormat>image/jpeg</ImageFormat>
        <Layers>modis,global_mosaic</Layers>
        <Styles></Styles>
    </Service>
    <DataWindow>
        <UpperLeftX>-180.0</UpperLeftX>
        <UpperLeftY>90.0</UpperLeftY>
        <LowerRightX>180.0</LowerRightX>
        <LowerRightY>-90.0</LowerRightY>
        <SizeX>2666666</SizeX>
        <SizeY>1333333</SizeY>
    </DataWindow>
    <Projection>EPSG:4326</Projection>
    <BandsCount>3</BandsCount>
</GDAL_WMS>
# this works:
qgis gdal_wms.xml
# this, too:
r.external /tmp/gdal_wms.xml out=gdal_wms
g.region n=90 s=-90 w=-180 e=180 res=1 -p
d.mon x0
d.rast gdal_wms
# this gets stuck:
d.rast gdal_wms
   0%
strace shows
select(8, [6 7], , , {0, 100000}) = 0 (Timeout)
poll([{fd=6, events=POLLIN|POLLPRI}], 1, 0) = 0
poll([{fd=7, events=POLLIN|POLLPRI}], 1, 0) = 0
Maybe some update magic is needed internally (but maybe
I am exaggerating right now...).
Have a look at r.external:
http://grass.itc.it/grass64/manuals/html64_user/r.external.html
~ Eric.
# this gets stuck:
d.rast gdal_wms
   0%
strace shows
Maybe GDAL can't handle skipping rows for WMS? Due to the region
mapping, GRASS typically doesn't request rows sequentially (it may
skip rows, or request them in an arbitrary order, even reverse order).
> unappealing.
However, this is only works for reading. Any maps created by GRASS are
still stored in the GRASS database, and need to be exported explicitly
with e.g. r.out.gdal.
Making it work for writing would require a way to obtain the various
creation options (i.e. file format, data format (UInt8, UInt16 etc),
output directory, probably a lot of other options). Implementation
shouldn't be hard, but specification and design might be.
On Thu, Oct 30, 2008 at 6:57 PM, Glynn Clements
# this gets stuck:
d.rast gdal_wms
   0%
strace shows
Here an offlist answer from Frank (fwd with permission):
On Thu, Oct 30, 2008 at 7:34 PM, Frank Warmerdam wrote:
I'm not too familiar with the WMS driver. But if it doesn't support
skipping rows then it is a bug and should be fixed. To file a ticket on
this issue it would be helpful if a demonstration of the problem could
be boiled down to a small C/C++ program or Python script just depending
on GDAL.
Adam Nowaki is the main author of the WMS driver.
Unfortunately I am not skilled enough in Python to write down the
requested test case.
> on GDAL.
Does "gdal_translate -outsize ..." work with WMS?
On Thu, Oct 30, 2008 at 10:24 PM, Glynn Clements
> on GDAL.
Apparently not:
gdal_translate -outsize 20% 20% wms_jpl_onearth.xml bla.tif
Input file size is 2666666, 1333333
0
... then it goes into poll time-out (according to strace).
>> > on GDAL.
Apparently not:
0
In that case, it's a GDAL issue, and that should be a sufficient test
case.
On Sat, Nov 1, 2008 at 5:29 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
>> > on GDAL.
Apparently not:
0
case.
Right. Filed as
http://trac.osgeo.org/gdal/ticket/264
