[GRASS-user] Using grass.run_commmand
Hi there
I’m using grass.run_command and I have one question: besides setting flags, parameters can I also get error and output from that function like
p=grass.run_command(“r.out.xyz”, parameters=X, flags=“f…”, stdout=output, stderr=error)
Is this possible?
Thanks
Luisa
Luisa Peña wrote:
I'm using grass.run_command and I have one question: besides setting flags,
p=grass.run_command("r.out.xyz", parameters=X, flags="f...", stdout=output,
stderr=error)
Use read_command or pipe_command.
read_command returns the command's output (stdout) as a string.
pipe_command returns the Popen object; read from its .stdout member.
Call the .wait() method when you're done with it. For details of Popen
objects, see:
http://docs.python.org/library/subprocess.html#popen-objects
The most general function is start_command, upon which all of the
*_command functions (except for exec_command) are built. Again, this
function returns the Popen object.
Refer to the source code ($GISBASE/etc/python/grass/script/core.py)
for more details. Most of those functions are only a few lines long.
Hi
Just one question:
is there any difference, when it comes to processing, between run_command and read_command?
and from read_command can I retrieve the error also?
THanks
2011/5/19 Glynn Clements <glynn@gclements.plus.com>
stderr=error)
read_command returns the command’s output (stdout) as a string.
Call the .wait() method when you’re done with it. For details of Popen
objects, see:
and read_command?
run_command() executes the command and waits for it to terminate; it
doesn't redirect any of the standard streams.
read_command() executes the command with stdout redirected to a pipe,
and reads everything written to it. Once the command terminates, it
returns the data written to stdout as a string.
None of the existing *_command functions redirect stderr. You can do
so with e.g.:
def read2_command(*args, **kwargs):
    kwargs['stdout'] = grass.PIPE
    kwargs['stderr'] = grass.PIPE
    ps = grass.start_command(*args, **kwargs)
    return ps.communicate()
This behaves like read_command() except that it returns a tuple of
(stdout,stderr) rather than just stdout.
