[GRASS-user] Using GRASS to compose displays
Greetings
I would like to define a composer template (e.g. scale always in the same place; north arrow also) and to export the generated compositions to JPEG/PNG. is this possible with GRASS?
On Tue, Nov 15, 2011 at 2:42 PM, Luisa Peña <luisapena1979@gmail.com> wrote:
Greetings
You may use the new cartographic composer which is based on ps.map:
http://grass.osgeo.org/wiki/WxGUI_Cartographic_Composer
