I've not needed GRASS for a while, but now I need to model hydrology for a
location.
Here, I removed the source directory ~/gis/grass/grass7_trunk/ which used to
be updated from the svn repository. I tried to replace the source with that
in the github master but failed. Please show me what I missed.
Following this instruction: "The GRASS GIS software lives in the Git source
control system hosted by GitHub. It can be browsed online using
GitHub UI. With the Git client software installed, various versions
can be accessed:
git clone https://github.com/OSGeo/grass.git"
$ git clone https://github.com/OSGeo/grass.git
Cloning into 'grass'...
remote: Enumerating objects: 120, done.
remote: Counting objects: 100% (120/120), done.
remote: Compressing objects: 100% (110/110), done.
remote: Total 229474 (delta 77), reused 35 (delta 10), pack-reused 229354
Receiving objects: 100% (229474/229474), 237.22 MiB | 1.78 MiB/s, done.
Resolving deltas: 100% (169917/169917), done.
Checking out files: 100% (7360/7360), done.
I see nothing different in ~/gis/grass; there's not a git repo there.
Anyway, I try:
$ git checkout master
fatal: Not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
Should I initialize a local repo (git init) in ~/gis/grass before cloning
and checking out the master?
TIA,
Rich
Rich Shepard <rshepard@appl-ecosys.com> schrieb am Fr., 12. Juli 2019, 01:03:
I’ve not needed GRASS for a while, but now I need to model hydrology for a
location.
Following this instruction: “The GRASS GIS software lives in the Git source
can be accessed:
git clone https://github.com/OSGeo/grass.git”
Cloning into ‘grass’…
I see nothing different in ~/gis/grass; there’s not a git repo there.
Anyway, I try:
Did you
cd grass/
To me it looks that you tried this in there parent dir.
No. Just be in the right directory.
HTH
TIA,
Rich
grass-user mailing list
grass-user@lists.osgeo.org
On Fri, 12 Jul 2019, Markus Neteler wrote:
Did you
cd grass/
Markus,
Yes. However, that was the problem because ~/gis/grass/ is not empty.
Creating a new subdirectory, grass-master/, allowed me to clone the
repository.
Now I have a configuration issue:
checking for location of zstd includes... checking for zstd.h... no
configure: error: *** Unable to locate zstd includes.
This was not an issue before. My web search for this header file suggests
that it it specific to facebook, which I do not use, and I have other
compression tools instaled (.Z, .gz, .bj2, .xv).
Please advise,
Rich
On Fri, Jul 12, 2019 at 3:18 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
> Did you
> cd grass/
Markus,
ok yeah: it needs to be empty since you got a completely new clone of
the source code repo.
repository.
Fine.
That is a new dependency (optional, you can use --without-zstd):
http://htmlpreview.github.io/?https://github.com/OSGeo/grass/blob/master/REQUIREMENTS.html
ZSTD -> https://facebook.github.io/zstd/
Probably your system:
https://slackbuilds.org/repository/14.2/system/zstd/
HTH
Markus,
I tried looking in configure but didn't see that because it's been a very
long time since I last looked at options in a configure file.
Was going to see if SBo had it. But, since it's optional I'll build without
it unless that might cause other problems down the road.
Thanks very much.
Best regards,
Rich
On Fri, Jul 12, 2019 at 4:00 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
Markus,
It will not.
Happy compiling,
